Question about KitchenAid KSRB22FKSS Side by Side Refrigerator
The ice production is very very low (about one tray a day) the water line is clear and the filter has been changed.
  • 11,896 Answers
There is a sensor that tells how much ice is in the bin. And also a bar that you can move that should activate it. It could be faulty. You can test *** with an ohmmeter to see if there is resistance in the ohm setting.
Posted on Nov 14, 2009
Kenmore side by side,no water going into the the Ice maker
"IF" the unit worked before the filter change you have to check a few things. First I want you to run a few cups of water from the in door water dispenser to make sure that all the air is out of the line and out of the filter. IF you encounter any sputtering in doing this it means that the air is coming out of the system. Keep it up until the sputtering stops then let it make ice until the cubes come out. Most of the time the air in the filter takes a few days to process thru the system and start filling the ice tray.
Second if the water comes thru ok without sputtering after five cups then check where the water goes into the back of the freezer compartment. disconnect the fitting and check for ice at that point. if ice get a pan of hot water and dip that end into it to melt the ice in the tube and then afterwards, reinstall it in the back of the fridge and make some ice. You can verify that it is not a valve problem by putting the tube end in a plastic container and letting the ice maker go thru a cycle or two. water should come out and be in the container in the amount of water it takes to fill the ice maker tray.
Third, is the check process of item two. Verify if water comes thru the tubing to fill the ice maker, If not, turn off the water valve supplying the fridge and check for grit in the line clogging the opening in the valve. if grit is present clean it as best you can. IF you have the proper tools and knowledge you can back flush the valve and remove the grit blocking the valve..
This should clear the line and verify proper working of the water control valve and filter. If at any point you have a failure in the checking process it should point you to the failure rather easily. If you suspect it is the valve verify from the label on it the operating voltage and IF, AND ONLY IF, you have a knowledge of electricity and test procedures test the valve with the proper voltage applied. IF you do not understand electricity, do not do it. you might injure yourself or worse.
Goodluck in your testing.
Feb 16, 2015 | Kenmore Refrigerators
Frigidaire French doors not making enough ice .
Hello friend, thank you for your post!
I understand that your Frigidaire refrigerator is not producing enough ice. I would advise to check and make sure that your water filter has a secure connection, if need be uninstall and reinstall the water filter to assure connection. Your filter should be changed every six months, if it is has not been changed recently I would recommend exchanging it.
If you continue to receive low ice production it could be an issue with your water line or water valve, I would seek assistance from a professional for proper diagnose and repair of your appliance. I hope this helps. -Matt
Sep 01, 2014 | Frigidaire Gallery FGHB2844LF 27.8 cu. ft....
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
Whirlpool ice maker makes impure ice but the water is crystal clear and good. replaced filter and cleaned ice maker tray ect.... no change. Is there a way to sanitize the water line to the ice maker?
what you are seeing in the ice is the impurities in you water. you wont see them until the water freezes because you are trying to freeze the "H2O" and not the calcium and magnesium. those are what causes your ice to look cloudy.
filtering the water does help but you cant get perfectly clear ice with this type of an ice maker.
when you see "store bought" ice and it is clear, that is because it is made a different way to prevent the impurities from forming in the ice.
also the longer the ice is in your freezer, the more it will absorb from the air causing even more cloudiness.
Jan 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water not coming out of fridge
First, I'm not a Whirlpool Tech.
*** Following is for information only.***
* Sputtering or no water from Ice machine and tap indicates a clog on the water line.
* Most of the newer (last 15 years) refrigerators come with a built in filter. It's probably clogged. Check the link below for changing out filter or type in "Whirlpool refrigerator water filter replacement'
* There could be ice blockage in water line if you have a very low temperature setting on your fridge. Most are set in the middle of the dial. If your set at maximum could then this setting may be too cold for the water line (it's coiled in the back of the refrigerator and may have frozen up.) Back the temperature a bid and give it a day or two to melt.
* The ice tray is missing a cover.
* Ice tray "Ice Full" lever is stuck in the Full position. Check if the Ice level (usually a stiff wire) is in the down or empty position. (some lock in the full position to turn off ice maker manually.)
* Check the water line to the refrigerator (or In-Line water filter) for water pressure. Turn off water supply. Remove water line from refrigerator and place end of line in empty bucket. Hold line down and have someone turn water back on then off after a few seconds (they may be too far to hear you yell "turn it off?!") If it just sputters then the line needs to be cleared. Check the needle valve for clogging. Close it off and re-open it several times. Otherwise this valve needs to be replaced.
* Follow the flow of water through each part: Supply line, supply valve, Water filter, Refrigerator inner filter, Tap point and Ice maker.
* Final, Check your warranty as any work (other than a MFR recommended customer water filter change out.) will void it. Call your vendor for service to be safe. (Have them do an annual maintenance while they are servicing your unit.)
Aloha, ukeboy57
Whirlpool link; https://www.bing.com/videos/search?q=whirlpool+refrigerator+water+filter&&view=detail&mid=B5D436DFC162C03FB4FAB5D436DFC162C03FB4FA&&FORM=VRDGAR
Feb 21, 2018 | Whirlpool Refrigerators
About a week ago, ice making slowed way down.
changed the water filter. cost $43 for a new one. crazy.
Jun 17, 2009 | Aspen Refrigerators
U-Line undercounter frost free ice maker refrigerator
All units made today have defrost timers to clear ice from the evaporator. Some of the ice sublimates...turns directly into humidity in the air in the box. It re-condenses in the ice tray area. It is possible that nothing is wrong other than excessive opening of the bin area or the defrost timer is running slow and staying on too long. You may also be consuming the ice too slowly. Can you either change the amount of ice in the bin by adding something to simulate part of the ice content or shut off ice production against low demand?
Dec 18, 2007 | U-Line Icemaker
Ice tray doesn't fill and jams
Sean, sounds to me like your inlet to your water valve is full of sand or some type of gunk. You may have to replace the valve, part number 61005626. Remove the connector at the valve in the rear of the refrigerator and with a small paper clip see if the opening is clogged. If not your best bet is to replace the valve. Easy job, a couple of water line connectors and harnesses. Im assuming you have changed the filter... Catriver...post back.
Aug 16, 2006 | Maytag MZD2766GES Side by Side...
KitchenAid KSRB22FKSS Side by Side Refrigerator Logo
15 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
