Question about Sony Playstation 3 (PS3) Console
Orange light flashing and system wont turn on
I can't turn my ps3 on. everytime i hit the power button, the machine beebs/flashes yellow and turns itself back off.
it was working fine this morning though.
help
    Problem Solver:
  • 5 Answers
Man that must have took a heavy fall
Posted on Nov 14, 2009
When turning on my console it wont fire up or eject the disc that is in the machine the Standby light flashes, beeps and then nothing ?
Maybe you have the "yellow light of dead"
You should let it repair, your console is broken.
try putting it in recovery modeHow to Access Playstation Recovery Menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
My playstation 3 console wont turn , when i try to it stops and a blue then yellow light flashes , what can i do to fix this.
source: http://www.edepot.com/playstation3.html#PS3_Model_Differences Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
  • Beeps Three Times
  • Red Light Flashes
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont stay on
charge it red light turning of and beeping is meaning its dead
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
MY PS3 wont start up, everytime i press the start up button it turns green for a second and then quickly turns yellow and shuts off
That yellow light is what us gamers refer to as YLOD.. Its the Yellow Light Of Death. Your system will have to be serviced by Sony. If your system is under warranty still it wont cost you anything but if its not, Sony charges 150.00 dollars to fix/replace it. They will send you a box in the mail to send it to them. Turnovers usually 2-3 weeks. My condolences to you and your PS3. Best of luck to you.
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
When I turn on my ps3 system on, there is no signal on my T.V.
With the system off, hold down the power button on your PS3 for 10 seconds. This should set everything back to factory defaults. If that doesn't work, try holding it down until you hear the beep that sounds when the system turns on. Keep it held until you hear 2 more beeps, and release it instantly. If it doesn't work after that, then its going to be a problem with either the power supply, meaning that its missing some off the voltages which powers on the system properly or the main board is bad, at that point you would have to call Sony Tech Support.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
My ps3 power wont turn on at all? i hit the switch but???
man i dont know what to tell you but to change your hard drive and and or get a new ps3 dude
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
216 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
