My Skype is not able to connect to the internet. I disabled my firewall, so that is not the problem. Please help me. My boyfriend lives in India, and skype is our only way. I am not very good in computers.
    Problem Solver:
  • 18 Answers
1-try reinstalling the skype with original configs
2- check for any proxy's
Posted on Nov 16, 2009
I cannot connect my skpye to the internet and thinking it may have something to do with my netgear wnr 1000 router. How do I allow it to access the internet?
option 1. check your firewall setting maybe it prohibits skype from accessing the internet. check if you have other firewall programs then check the settings. if it is ok try to disable your firewall.
option 2.try if you can use your internet connection without using the router then try using skype. if it works there is problem with the router settings. if not your problem with the skype try to reinstall it.
Apr 09, 2011 | Computers & Internet
Password
Check This file at youtube might help you out.
Sep 26, 2008 | SKYPE Lands Phones
I try to sign in on skype and it says, "Skype can't connect. Get help fixing this probolem."
  • If you are on a network that uses a proxy server, make sure your proxy settings are correct.
  1. In Internet Explorer: In the menu bar, click Tools > Internet Options > Connections > LAN settings.
  2. In Skype, in the menu bar click Tools > Connection options...
  • Make sure your firewall allows exceptions.
  1. If you are using Windows Firewall, click Start > Control Panel > Windows Firewall, and make sure that Don't Allow Exceptions is NOT ticked.
  2. If you are using a different firewall, click Start > All Programs and select your firewall. Make sure that exceptions are allowed. If Skype is listed in the Exceptions tab, remove it.
  3. Sign in to Skype. When prompted, select Yes to allow Skype to connect to the internet.
  • Ensure that Skype is able to use port 80 and 443 as alternatives for incoming connections.
Mar 30, 2011 | Skype IM
Skype isn't letting me log in
If you are sure that you are typing in the correct password, then you might need to check your router settings.
Try to reboot your router first, then try again. If you still experience the same issue, you now have to check the firewall settings. Please see instruction per Skpe;
  1. If you are on a network that uses a proxy server, make sure your proxy settings are correct. To check proxy settings in Internet Explorer, go to Tools > Internet Options > Connections > LAN settings. To check proxy settings in Skype, go to Tools > Options > Advanced > Connection.
  2. Check your firewall settings. If you are using the Windows inbuilt firewall, click Start > Control Panel > Windows Firewall, and make sure Don't Allow Exceptions is not ticked.
    If you are using a different firewall, click Start > All Programs and select your firewall. Make sure that exceptions are allowed. Go to the Exceptions tab. If Skype is listed, delete it. Start Skype. When prompted, select Yes to allow Skype to connect to the internet.
  3. In Skype, go to Tools > Options > Advanced > Connection and then un-tick Use port 80 and 443 as alternatives for incoming connections
Oct 26, 2010 | Skype IM
My skype can't connect to internet.I download it again.but i have the same problem! could help me pls?
This is may be because your firewall is blocking skype connections!
Go to Control Panel then open Windows Firewall, Just click on the exception tab and try to see if you can locate skype there! If not browse to add skype.exe in the exception list!
C:\Program Files\Skype\
Hope this will help you in resolving the skype issue for you.
Cheers!!!!
Vivek
Dec 31, 2009 | Skype IM
Cannot connect Skype to Internet?
There is a version 4.1 Skype. You might need to upgrade by going to skype.com. If you already have the latest upgrade and you are on a LAN you might want to configure your LAN settings to allow access for skype. Otherwise, if you have a direct internet connection and you can get on the internet with your browser, you'll need to configure your connection to allow skype. If you have McAfee or Norton or another firewall you'll have to go to the program permissions to allow Skype. If you are also using Windows Firewall you can follow these steps to allow Skype to pass through your firewall.
Go to START + CONTROL PANEL, THEN RIGHT CLICK ON NETWORK CONNECTIONS. IN THE DIALOGUE BOX CLICK ON PROPERTIES. IN THE NEXT PANEL CLICK ON "ADVANCED". There you can set your Firewall settings to except Skype, Just click on SETTINGS + ADVANCED + EXCEPTIONS. Make sure Skype is checked. This will tell your computerl to allow skype to access the internet without being blocked by your firewall.
I hope this helps, but usually when you install Skype these settings are changed by the setup program. I suspect you have a firewall you will have to set manually. If you use Zone Alarm or some other firewall you will have to search the for help on your firewall support pages.
Oct 01, 2009 | Computers & Internet
Skype shuts down when I enable the video on Skype. I tried using an older version of Skype but still encounter the same problem, any ideas out there
With updating SKYPE your firewall must be updated as well.
Exit/Close your current Skype by clicking in system try Skype icon (down near the right corner green spot)
and choosing “Quit” from there if needed.
Open firewall, in programs, deletes Skype.
Run Skype and allow connecting
This also affects SP2 users who should follow above procedure.
With SP2 firewall.
Disabling external firewall will enable XP firewall by default.
So if you disable any other firewall XP firewall will now block your connections.
So remove Skype from XP firewall program list as well
dont forget to vote fixya rating
Sep 13, 2009 | Logitech QuickCam Pro 9000 Web Cam
I can't get the skype download to work with my Acer Aspire One, Windows XP netbook.
Exit/Close your current Skype by clicking in system try Skype icon (down near the right corner green spot) and choosing “Quit” from there if needed.
Open firewall, in programs, delete Skype.
Run Skype and allow to connect
This also effects SP2 users who should follow above procedure.
With SP2 firewall.
So remove Skype from XP firewall program list as well and for more info contact http://tinyurl.com/m7ghqz
Jun 20, 2009 | Computers & Internet
Router not working
Hello Sean Lin,
The only option for the 5th pc would be to get it wirelessly connected. You need to install a wireless adapter to your pc. Set the IP & DNS to automatically obtained from router.
You also try to adjust or temporarily disable the your firewall and other securities;
Disabling Windows Firewall
Note: A firewall is designed to help protect your computer from attack by malicious users or software. Such software includes viruses that use unsolicited incoming network traffic that infects your computer. Before you disable your firewall, you must disconnect your computer from all networks, including the Internet. To disable your Windows firewall, please follow these steps:
Disable Internet Connection Firewall in Windows XP or Windows XP SP1
1. In the Control Panel, double click Network and Internet Connections. Then, click on Network Connections icon.
2. Right click on Local Area Network (LAN) Connection on which you want to disable the Internet Connection Firewall (ICF), and then click on Properties.
3. On the Advanced tab, you will see protect my computer or network check dialogue. Then, click on the Settings tab.
4. Click on OFF then OK.
Disable Windows Firewall in Windows XP SP2
1. Please click on Start, then click Run. Then, type in firewall.cpl and then click OK.
2. On the General tab, click OFF (not recommended) and then click OK.
I hope this troubleshooting steps will help..if not please notify me
Nov 20, 2008 | NetGear WGR614 54Mbps Wireless Router...
Vodafone Mobile Modem not allowing Skype to work
The baud speed and bandwidth of the E220 may not be able to keep up with the huge data speeds and bandwidth required by online connections that use video.
Nov 21, 2017 | Vodafone Mobile Connect (055270) Wireless...
Computers & Internet Logo
367 people viewed this question
David Payne
David Payne
