Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Problem with new Carrier Infinity 96 gas furnace
Hi
Just had a Carrier Infinity 96 (40000BTU) installed a few months ago in our 1500 sq ft home.
My wife likes to keep our bedroom window open at night for fresh air, which, of course, cools down the house. Before going to bed, we turn down the thermostat to 15 degrees celsius. We turn it back to 20 degrees in the morning after closing the window. The problem is that it takes several hours to bring the temperature back up to normal. Shouldn't it heat up the house faster than that? Is there anything I can do to make it heat up faster?
Thanks for any help,
Bill
Vancouver, BC
Canada
Carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
Posted on Jan 14, 2010
Yes, we have a larger model and the reason it takes so long to warm up is that your technician set the thermostat for a slow warm up which is used to conserve energy. Or else it is the default setting. It can be turned off by holding down the "Advanced" setting on the thermostat for 12", going to settings ,furnace, and "low heat rise" where you can shut that off by pushing up or down on temp button. I went to this site b/c we are having problems with it starting up on High blower and then dropping down after a few seconds. Just started doing that. I changed the filter and it doesn't seem to be doing it as much.
Posted on Dec 23, 2009
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Apr 07, 2015 | Heating & Cooling
How much water gal/hr is reasonable to expect from the furnace humidifier overflow in "0 degree" farenheit outside to heat a 1500 square foot normal midwestern house to 72 degrees inside having a norm
There is no flow rating because it would depend on too many factors. What you do need to check is the float valve. The water valve is opening and closing like it should be but the reservoir is filling too much.
Jan 23, 2015 | Humidifiers
How many gallons of propane will I use per month?
Go on to google and use BTU per gallon calculator at Irving energy this will give you the price between them both
Mar 06, 2017 | Heating & Cooling
We have a Carrier Infinity 96 furnace in our home, which was installed brand new in our house we built 5 years ago and this thing is a nightmare. We've had the code blinking away and and the technician in...
EACH OF THE FOLLOWING STATUS CODES IS A TWO DIGIT NUMBER WITH THE FIRST DIGIT DETERMINED BY THE
NUMBER OF SHORT FLASHES AND THE SECOND DIGIT BY THE NUMBER OF LONG FLASHES.
43 LOW-HEAT PRESSURE SWITCH OPEN WHILE MEDIUM-HEAT PRESSURE SWITCH IS CLOSED - Check for:
- Low inlet gas pressure (if LGPS used).
- Plugged condensate drain.
- Improper pressure switch wiring.
- Water in vent piping, possible sagging pipe.
- Stuck open low-heat pressure switch.
- Disconnected or obstructed pressure tubing.
Mar 28, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Excessive water usage with Carrier LBP humidifier.
hi the water runs down the pad the fan blows air across is , this controled by the stat which should control the water flow / on or off, this should be under warranty in the first year
Mar 01, 2010 | Carrier LBP Humidifier
I have a Carrier Infinity 96 gas furnace with no heat
That means that the furnace is throwing a code to trouble shoot whats wrong. Most of the time, furnaces will have a code list on the inside of the door cover to explain what each code means, some of them don't. Its hard to say what it could be without knowing where to start. However, answering a few questions with someone knowledgeable over the phone if possible could help speed things up, but it would involve you being at the furnace and seeing what happens before it throws the code. If you do have a code list, this would help tremendously.
Feb 03, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
4 ton HVAC Unit for 2000 SQ FT Residential Bldg (Single Story)
One ton of cooling per 500 square feet of space assuming you have good insulation. Yes, 4 tons for 2000 feet would be accurate.
Jul 21, 2009 | Ruud UBHC Air Conditioner
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Carrier Infinity DC motor drive problems
Contact the company that installed the unit. Its new, under warranty, Anything you do could void the warranty. If they do not take care of the problem without charges contact Carrier and tell them what's going on. The company who installed the unit is responsible for making it run correctly. Good luck. kstfas
Aug 26, 2007 | Carrier 38CKC036 Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
1,611 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
