Question about Frigidaire GLEQ2152ES Electric Dryer
CAN A 220 BE CONVERTED TO A 110 - Frigidaire GLEQ2152ES Electric Dryer
  • 576 Answers
If you mean can a 220 volt dryer be converted to run on 110, the answer is no. It needs the higher voltage to run the heating elements. It would be possible to make a 110 volt electric dryer, but it would require very thick wire and a very large breaker to handle the amperage that would be required. Sorry I couldn't give you better news.
Posted on Nov 17, 2009
Requires 220v, can it be converted to 110v?
NO
if the plate states 220 volts ten it has be constructed to run 220 volts
if you powr supply is 110 volts you may be able to get an inverter that will boost that power supply to 220-240 volts
Mar 31, 2016 | Bosch TASSIMO Coffee Makers & Espresso...
Can it run on either 110 or 220?
There should be a label on the motor that explains the capability.
A very advanced table saw may have a motor that can be wired for either 110 or 220. The table saw I can afford would have a either a 220 or 110 motor.
Apr 28, 2015 | Saws
Converted from 220 to 110 voltage
Have a look at the rating plate, it should state if it's dual voltage, if so there will be a movable link under the rating plate or somewhere obvious. If it isn't dual forget it, the wattage precludes using a ballast
Jun 26, 2014 | Air Tools & Compressors
How can we adust the air flow on our hot tub?
when you say it's converted to 220 volts , did you just change the voltage on the pump motor or did you also change the voltage on the blower motor as well ?? reason i ask is you might be feeding a 110 motor with 220 power it's turning twice as fast so it makes too much air , might be your cause ?
Jun 15, 2014 | Jacuzzi Pool & Spa
My nexxtech multination travel adapter specifically says on the label that it will convert 240/220 V to 120/110 V, but when i plug it into a 220 V wall outlet its output is still 220 V. (I know this since...
It seems your adapter is not a converter for Voltage, but just a plug-converter so it will fit all type of sockets. There's a varistor for safety-protection, but that's all there is. At least, that's what I make up, based upon your description and the manual. See http://downloads.thesource.ca/273/2731445/manuals/manual.pdf
If the converter also should have converted 220/240 V AC into 110 V AC, than the electronics inside is damaged. Actually I think it's just a plug-converter, because there are many devices operating with an internal switched powersupply. The advantage of such technique is it can operate at various AC-voltages, whil only an adapter for the correct plug is needed.
Oct 16, 2013 | Computers & Internet
Can i change the model T101P3 timer from 110 to 220?
1) Yes. Change clock motor from WG1570 to WG1573
Wiring is same as T102 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T102
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
2) If new pump motor is 2-speed, then converted T101P3 cannot handle 2-speed pump.
Use T106 timer, or T1906 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#2-speed
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html#pool
3) New T106 or T1906 timer mechanism will snap into T103P enclosure without changing boxes.
Any intermatic timer will snap into Intermatic enclosure.
Other brands of timer can adapt to Intermatic enclosure using Tork IAP adapter bracket.
Mar 10, 2013 | Hardware & Accessories
Could jvcrx 778 be converted from 110 VAC to 220VAC power input ? or is it an auto volt
if it says 110/220 on the bk and there isnt a switch to change to 220 its auto but if it doesnt say 220 on there dont plug it into 220 this unit has a built in power supply so if you do 220 and its not rated for that itll fry.
Jan 30, 2011 | JVC RX-778V
Not a problem just want to turn it into a 110 pump from 220
Not all pumps can be converted.
If you open the back of the motor that you are trying to wire, there should be a wiring diagram on how to wire the pool motor either 220 to 110. Its relatively simple to follow, since you are only going to be connecting 3 wires.
Without knowing the manufacturer of the motor, the size, or the style, it is nearly impossible for us to walk you through or provide an alternative schematic.
Take a look and see if there is a wiring diagram, if not, go ahead and gather the additional information off the motor and come on back to us.
The Ugly Pool Guy www.WeFixUglyPools.com
Dec 30, 2010 | Pool & Spa
About converting from 110 volt to 220 volt Sonance Cinema 5150
Yes no problem all you need is a transfromer that converts 230volts AC to 110 volts AC.
Have a look in your yellow pages to find a Transfromer company
located in your vincinity.
You will need to visit him with the wattage of your amplifier and order a step down transfromer. (The wattage is found on the small plate on the rear of the amplifier. Sometimes its written as KVA?.
Please ensure that the plug on the amplifier is changed to specially fit the 110v output of the transformer this is a must as people plug the wrong plug into the wrong socket and burn out the amplifiers.
Cheers YUBEUT.
Apr 19, 2008 | Sonance Cinema 5150 5-Channel Amplifier
Frigidaire GLEQ2152ES Electric Dryer Logo
145 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
