Question about Dryers
How to put new belt on dryer model
How to put new belt on Roper dryer
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Nov 14, 2009
SOURCE: Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Posted on Jul 10, 2008
protek480
  • 1714 Answers
SOURCE: trying to put a new belt on a roper dryer model
Look at these illustrations. One of them is yours, it will give you the idea...
Posted on Sep 03, 2009
jsrock516
  • 5911 Answers
SOURCE: what is the routing of a dryer belt?
To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
You can also refer to pcappliancerepair.com for some excellent exploded view diagrams of your dryer. Just type in your model number as "GL6050VL0" (the last digit is a zero, not the letter O), and go to the "Bulkhead" section.
NOTE: Roper is manufactured by Whirlpool, so these instructions will apply.
If you have questions, or require additional assistance please let me know. I hope you find this information helpful.
Posted on Oct 17, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I want to know how to put the belt on my roper
This method works on Whirlpool,Kenmore, but I am not l00% sure of Roper, you might give it a try.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
Posted on Dec 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: how to replace a dryer belt on a roper dryer
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good luck, I hope this helps Please do not forget to rate me Thank you
Posted on Apr 09, 2010
Dryer works and come on but won't turn to dry. its a roper by whirlpool
Check your belt.
This video on replacement should help you in opening the top panel so that you have a good view of the drum and belt (turn off the breaker and unplug your dryer before proceeding with any work).
http://www.youtube.com/watch?v=GZsDbMuimm8&feature=channel
Replacement procedure is the same as shown in the video. If the belt is broken check the tension pulley on the bottom before purchasing or ordering a new belt, some Roper model came with a "tension slide" and not a tension wheel (mine was one of them).
http://www.applianceaid.com/WLP_idler_slide.html
The slide will wear and a groove will form that will accelerate the wear on the belt, this part can be replaced with a normal tension wheel (recommended), so you're not repeating this repair in another few months or so.
Apr 23, 2011 | Roper Dryers
I have a 9 year old Roper dryer. Went in today to turn it on and the motor sounds like its running, but there doesn't seem to be anything turning and I hear a high pitched squeaking sound. Any thoughts??
The problem is likely the dryer belt . Here is a video Dryer belt replacement video . It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Feb 21, 2011 | Roper REX4634KQ Electric Dryer
How do you connect the belt to the pully, and drum?
loop the new belt around the drum,then take loop of belt under the idler pulley wheel and pull back on wheel to get slack to put remaining loop onto motor pulley shaft,then slowly release and idler will tighten up the belt automatically
Jan 02, 2011 | Roper REX4634KQ Electric Dryer
Needs a new belt? Dryer not turning Roper, model unknown
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 06, 2010 | Roper REX4634KQ Electric Dryer
Dryer will heat up but drum will not turn. Unable
Good day,
Sounds like a broken belt, Excellent tutorial on changing the belt on the link below.
Caution: Some models used a very poorly designed belt tensioner. If the tensioner is that style, replace it while purchasing the belt.
Appliance parts house counter men are well aware of the problem. The Roper line is made by whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 04, 2009 | Roper REX4634KQ Electric Dryer
Trying to put a new belt on a roper dryer model number rel4632b
Sep 03, 2009 | Roper Dryers
Roper Dryer
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
