Question about Saeco Odea Go
Saeco Odea Go - slow to brew coffee, comes out of steam valve
Saeco Odea Go - slow to brew coffee and the rest comes out of the steam valve. We have done all we could using the manual. It continues to get worse and worse.
    President:
  • 1,618 Answers
The steam valve needs to be replaced, because the pins have been damaged from high pressure buildup, could have been caused from a very fine grind. You can also check the screen in the brew unit that might be blocked and causing the high pressure backup.
Posted on Nov 15, 2009
Steam dial turns on in the middle of coffee brewing. Brewing stops. Have to hold dial to prevent it from turning. Saeco Go Plus II
The brewing pressure will backfeed into the steam circuit if you forget to turn off the power for the steam on most units. That combined with calcification in the valve will cause it to open. I don't know if this is your particular problem.
I would really recommend you don't ever put tap water, and definitely never put "magic" water (Kangan, etc.) into an espresso machine. Both will screw it up proper. I never put anything but steam distilled water in my machine, and I have never had to run vinegar through it. It's inexpensive, and will save you a lot of trouble.
A lot of calcium in the valve, or in the brewing circuit would most likely allow the valve to be forced open, even without the steam heating element on.
May 07, 2011 | Saeco Odea Go
The brew group is stuck and will not come out
I hope one of this two solutions solve your problem.
1- The brew group is out of place. Turn the machine on. Close the service door.
The brew group is automatically placed in the correct position.
2-Coffee grounds drawer is inserted. Remove the dregdrawer first, then the brew
group.
Jan 15, 2011 | Saeco Odea Giro Plus Coffee Maker
With the steam spout turned on, no steam is ejected, alarm light
Does water comes out when turn on the knob? If it is, try making steam, it should come out also. Make sure the knob is turned fully.Probably the seals in the valve is jamming and preventing the knob to turn fully.
Apr 14, 2010 | Saeco Odea Go
I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Mar 23, 2010 | Saeco Odea Go
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
Saeco Odea Giro Plus spare parts needed
The coffee dispensing valve is available at your saeco dealer 1-2 hr job to change...
Sep 27, 2009 | Saeco Odea Giro Plus Coffee Maker
Machine stoppped working
Try this remove the brew unit and clean the screen on the unit, then insert unit, and open steam/hot water valve to prime. If that does not work then there might be a malfunction with the pump, I am assuming that the machine is only 2 weeks old?
Jun 25, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Giro - alarm light continually slow flashing
I had the same problem. I filled everything up and closed it then took the hopper top and placed a small magnet that fit the circumference of the hopper sensor (I took one off of a refrigerator magnet and it fit down into the sensor) and it immediately went green. Hope it works for you.
May 02, 2009 | Saeco Odea Giro Plus Coffee Maker
Steam valve broken
I don't know if this will help, but here is your user manual:
http://www.wholelattelove.com/manuals/Saeco/Odea%20Giro%20Full.pdf
-Tha Mp3 Doctor
Mar 20, 2009 | Saeco Odea Giro Plus Coffee Maker
Open Questions:
See all Saeco Odea Go Questions
Saeco Odea Go Logo
719 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
