Question about Jenn-Air JGS8750 Gas Kitchen Range
Where could I found the replacement part #AP368708 Maytag switch membrane?
  • gagnon_rene Nov 15, 2009
    The control panel part number is S176W for my Jenn air oven
Essai de le rebatir ou de le trouver sur E-Bay
Posted on Nov 15, 2009
Door stayed shut and error code f1
You may have to replace the touch membrane or replace the electronic board behind the touch membrane. Also try removing power from the stone for fifteen minutes.See what happens.
F1 = failed electronic range control (erc)
Oct 24, 2013 | Maytag MGS5775B Gas Kitchen Range
How do I run the Membrane pad check on dryer, Maytag model MDE6700AYW
To Enter Service Mode:
Document 1
Document 2
Document 3
I didn't see your model number posted so hopefully this is for the right model.
Oct 14, 2012 | Maytag Dryers
Dryer randomly beeps, like morse code and changes ...
sounds like a stuck or shorted membrane switch.
which would require replacing the console. if you can access the tech guide in the control panel you can do a membrane switch test and other diagnostics.
May 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Jan 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
My maytag drying center has an electronic start button that will not work, is there another way to start the machine?
I had the same problem, membrane switch shot ($300). I added a monmetary switch from RadioShack on housing and wired it onto membrane connector (contact to Gnd). Wiring diagram should be behind membrane assy.
Jun 27, 2009 | Maytag Neptune MCG8000AW Gas Dryer
F1 message on Maytag range
This is what the code means.
F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC)
Good Luck and Please Rate
Jan 08, 2009 | Kitchen Ranges
Beeping in my Neptune Dryer
This is a mystery to me. Try typing into google "beeping sound on Neptune dryer". There may be a solution on there from Neptune or someone who has had a similar problem.
Jun 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Panasonic NN 9859 Membrane switch
Yes, you are correct. The membrane switch for this model was discontinued. The correct part number for the membrane switch is A630Y5460HAP for model NN 9859.
Mar 26, 2008 | Panasonic NN-T888S Convection/Microwave...
Neptune front load washer buttons wont work
I tried un pluging the machine for few hours and it will work for 3-4 load and then it will lock up again
Nov 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Jenn-Air JGS8750 Gas Kitchen Range Logo
209 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
