Question about Plumbing
Looking for assembly schematic for Wayne Porta Pump model PC4. Trying to replace propeller
  • mrrquinn Nov 17, 2009
    Obviously I had serched the internet to no avail. which is why I posted the question. If you know a specific web site, that would be of great assistance. Appreciate your response. Thank you.
    Sergeant:
  • 399 Answers
Hi you will find it on the internet
Posted on Nov 16, 2009
Flush pump not working
Unless the inlet pipe has dropped off the pump assembly or got a blockage in it then you may need to replace the pump bellows.
Here is a link to a schematics pdf with all relevant part numbers. These parts are readily available from most camping and caravan equipment suppliers. http://www.leisureshopdirect.com/camping/tents/porta_potti_toilets/Thetford_Porta_Potti_335__345__365_and_spare_parts.aspx?pdf=3880
Feb 22, 2011 | Maximum Thetford Porta Potti 365 Portable...
I am looking for a porta potti for a small space under a rocknroll bed in a VW camper - I have been told I need a 235 but I can't see one?
I have just come across the same problem. Looking at Porta Potti measurements, the 335 is the closest to the 235. Height of the 335 is half a cm more at 30.5cm. Depth is a couple of cm more at 38.1cm compared to 36cm for the 235, but width of the 335 is less at 34.3cm compared to 35cm for the 235 model. I was told the 345 replaced the 235...but the height is more and won't fit under my bench seat. 345 measurements are H. 34.5cm D.41.9cm W.38.1cm.
Sep 26, 2010 | Thetford Porta Potti
Hi, Wayne PC4 pump doesn't work. Can anyone help me?
The most common issue with these pumps is that the impeller gets stuck from non usage or from debris getting stuck in the impeller.
Take the cover off of the pump section and make sure that the impeller is free of debris and that it will turn freely. If it turns hard you may be able to free it by working it back and forth. This may take some time to do. I'm not sure about this particular pump, but on some you can get a lubricant like WD-40 worked into the pump and motor bearing also...
If the impeller is spinning frreely and the motor still does not turn on then you have a bad motor. To replace this motor will probably cost nearly the price of a new pump. It may be better to just replace the whole pump.
Heatman101
Mar 15, 2010 | Wayne Water Systems Plumbing
How to get to the pump in a porta potti 32
Have resolved the issue. Many thanks
Oct 17, 2009 | Thetford Porta Potti
Seal leaking on motor side of wayne pc4m pump
Wayne sells parts direct and deals direct with homeowners as well as contractors. You can reach them here.
Oct 08, 2009 | Wayne Water Systems Wayne 1/2 Hp 115 Volt...
Leaking at the rotor area after installing new rotor and gasket.
there is an o ring just before the rotor area ,this have been wear that is causing the leak
Aug 20, 2009 | Wayne Water Systems Wayne 1/2 Hp 115 Volt...
Im trying to find the wiring am for a thetford C2 porto potti
Go to www.thetford.com.
Click Customer Support then Product manuals and download manual in PDF format.
Wiring of C2 has fuse, safety switch, flush switch and flush pump in series. If fuse is blown you probably need to replace pump. Instructions come with replacement pump.
Jun 04, 2009 | Thetford Porta Potti
No information on Wayne 55701-RP1
This isn't a valid Wayne pump model number according to Wayne's website. Please double check your pump and visit:
http://www.waynepumps.com/producttype.aspx?pt_producttypeid=8
May 23, 2009 | Wayne Water Systems Wayne RECONDITIONED...
Plumbing Logo
245 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
