Question about Poulan Ght225 25cc Gas Hedge Trimmer
My rope is stuck in the in position and will not pull out
  • 563 Answers
You have to tear-up the area where its stuck at to free the rope.
Posted on Nov 14, 2009
Starter rope won't pull on my Craftsman rotary mower model 917.4787A.
the cable may be stuck or you may have to take the top off and rewind the rope.
Nov 05, 2016 | Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
How do I replace the pull cord on snapper sr1330 riding mower
remove coil cap look at the rope pulley pull old rope forward till you get to end knot hold pully pull not out with the rest of the rope then wind pulley up till it wont go any farther back off one turn alighning the cover hole with pully hole use ascrew driver stuck between the slot on cover and pulley ten get your rope take a lighter and burn the end of the rope the take a rag pul the end of burt end of the rope shuold leave a pointed rope then take rope and stick through pully hole then the housing make the rope about 70 iches long it will be to long i no but just do it tie a knot in tend on the back of pully take lighter and heat it still it melts a very little the knot that is pull rope on through pulley hold rope remove screw driver slowly let rope wind up on pulley still it stops you will have rope sticking out reistall pulley cap then put handle on rope put handle all the way down to cap pull rope one turn push handel down to cap atie a knot in rope as close to to handel as possible heat not like the other end cut rope with 1/2 inch of rope sticking out of knot
Sep 13, 2014 | Snapper Garden
Model 20005/ How do I fix a pull rope that is stuck?
remove the recoil. should be three 10mm bolts (maybe four) you may find that as you loosen them the rope might recoil so be careful. if not your spring is broken and needs replacing
Jul 05, 2014 | Toro Power Lawn Mower
Can't pull starter rope on Troy Bilt tiller
take the spark plug out and see if it will pull then. be sure there is no obstruction in the tines and that they are disengaged.
Nov 18, 2017 | Troy-Bilt Garden
The gator mount became stuck in the down position with the motor deployed into the water. The release rope would not release the lock to return the motor to the storage position so that I could operate...
mos minn kota motors have a pin that is spring load to lock when the motor is deployed. when you pull on the rope to lift the motor the pin is pulled forward to release and allow you to lift motor. sometimes it is necessary to put some pressure on the motor as if you were trying to push it farther in the water as you are putting this pressure on the motor pull on the rope to release the motor be very careful to avoid getting your hands or fingers in the way. when you get the motor up be sure to put a small amount of grease on the ends of the pin to prevent this from happening again.
Feb 25, 2011 | Garden
Rope will not retract.
I am assuming you tried to pull start and the rope is stuck out. Just try pulling the rope while it is out, but stand on the hedge trimmer. Sometimes when this happens to me, I just pull the rope a little extra and then hang onto it when it goes back in. Alot of times, I think the rope gets caught on the outside of the retraction pulley causing a tangle.
Aug 05, 2010 | Poulan Ght225 25cc Gas Hedge Trimmer
MTD Yard Machine CD000147 6HP 21 inch ..The problem is "Cannot pull the starter string for start. The string or engine stuck to pull the starter. We didn't use it for the whole winter.
The operator presence bail must be in the run position to release the flywheel brake. If you can't pull the rope with the bail in the run position, your rope is fouled. You will have to remove the shroud and take it to a repair shop.
Apr 19, 2010 | Mtd 22" Yard Machine Push Mower
The rope on my generator gets stuck as i pull to turn it on
Assuming the rope stays on the internal pulley, it is NORMAL for the rope to require great force at points in the cranking cycle (once per revolution of the crankshaft). These are the compression strokes and the force is MANY times the initial pulling force. If the rope returns easily, then the starter assembly is probably normal. It takes a strong arm and fast movement to start the enginess via pull rope. Some units have a compression release to ease this a bit.
Mar 22, 2010 | Electrical Supplies
Poulan Ght225 25cc Gas Hedge Trimmer Logo
222 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
