Question about Sony KP-57HW40 57" Rear Projection Television
Overheating problem?????? The TV currently has an issue that causes the screen to flicker green and shut off, typically after an hour or so after being turned on. It seems as if it may be an overheating issue since it occurs repeatedly once the TV has been on for awhile
  • deals4kiana Apr 20, 2009
    My TV flicks green and then shuts off. it just started 2 days ago.
  • 4,402 Answers
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Posted on Jan 14, 2008
HDMI from new laptop is causing intermittent flickering.
i would suggest a different refresh rate. should be in display properties.
Jun 17, 2015 | Sharp Televison & Video
What is Causing my My Samsung la40d503 to flicker green
5 month old TV should be under manufacturers warranty - do not attempt repairs yourself it will void warranty
Dec 05, 2013 | Samsung LA-40D503 40" Multi System World...
Lg r405 laptop screen flickering
most likely a loose connection if it is flickering.. if there are red squiggly lines usually means driver issue.. and if there are blue banding lines, typically means the chip is overheating/desoldering.
Mar 07, 2013 | LG R405 LAPTOP LCD SCREEN 14.1" WXGA CCFL...
Mitsubishi wd-60738 overheating
Look in the back for the fan area and see if you can feel/see it running. May be blocked or need to be replaced
Sep 16, 2012 | Mitsubishi WD-60738 TV
My TV will flicker at times and go completly black for a period. I unplugged everything and let it sit for about 12 hours and the TV worked fine the next day. The following day the TV again flickered and...
The screen flicker than go blank,does it still have power to the tv set?Yes,than this cause only can be causes by only 2 boards in the tv can causes this problems,if tv power still stable for the set.The T-CON board it shorting out and dying for this problems to happen or worst case causes the Main board tv Tuner signal board it dying.The T-CON board the priced it is cheaper and could cause this problems too.Tries change this T-CON board first,see what happen.This board T-CON board sit at the bottom in the middle of the LCD screen panel to decodes pictures pixel before it go onto the LCD screen panel.Tries websites like, to buy a refurbish T-CON board for the replacement.
Jul 27, 2011 | Samsung LN-T4071F 40 in. LCD HDTV
Samsung HLR5067W: Screen goes black - Audio Remains. Several months back my 5 years old HLR5067W started displaying the following behavior: - Launches OK - After running for a while (anywhere between...
When was last time you replaced Lamp? Ballast Board is what powers the lamp on.
Lamp Fan, if it is defective it will shut lamp off to protect it, if it is Not cooling the Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Encompass Parts Distribution has 10 Ballast Boards in Stock for $68.96 they also list Service Manual Free for this Model# 1-800-638-3328
Nov 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
1. After being on for 1-2 hours the pic goes out and turns to "the green screen of death". Pic will not come back on unless TV cools for 30+ min. 2. When I switch from DVD source to cable TV source the pic...
You got an issue with overheating.  TV is designed to shut off to protect electronic components if TV overheats.  Take it to the shop and have them open this thing up to identify the faulty circuit.  Also, check to make sure your not blocking the heat vents.
Nov 11, 2009 | Hitachi 70VS810 70" Rear Projection HDTV
TV blinks green then shuts down
absolutely, and if he spilled any of the fluid on the parts below the tube your looking at bigger headaches down the road, the coolant fluid is very caustic, stop running your tv and get a tech to check out your set right away, video-tek
Jun 07, 2009 | Akai PTH5498 54" Rear Projection...
REDENT PURCHASE OF TV'S Have green in some spots.
This is typically referred to as a color purity problem and can be caused by two main things. The first cause can be stray magnetic fields which can 'magnetize' the TV screen either by something magnetic begint oo close to the screen or having turned the direction of the TV while it is turned on. If this is a purity issue caused by magnetic fields, it can usually be cirrected by powering off the TV for about 1/2 hour and turning it back on. All tube TVs have build in 'degaussing' circuits to cure just this issue.
If this doesn't fix it the other cause is a shifted shadow mask inside the picture tube itself and cannot be corrected.
May 25, 2009 | Televison & Video
Sony KP-57HW40 57" Rear Projection Television Logo
196 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
