Question about Kitchen Ranges
What does error code F7 mean for a maytag electric range model cre9600cce
  • 149 Answers
Function key shorted or a stuck button. unstick the button and you are good to go if not you will have to replace the pad
Posted on Mar 23, 2010
F7 error code on GE gas oven model # JGBP90MEA2BC
On this model, code F7 means there is a keypad malfunction, and therefore the range's "computer" isn't getting a valid signal from the keypad. It may be a stuck "touch-key", a bad connection between keypad membrane and the range/computer connector, or more probably a faulty keypad membrane.
In some cases it can be a defective computer module. You can test whether the problem is the keypad or computer unit by disconnecting the keypad entirely. If an error code F7 still shows, then the computer is faulty.
If this was helpful, please rate via the helpful button.
Nov 04, 2014 | Kitchen Ranges
What is an F8 error code meaning? Thanks!
From this website ::
http://www.ehow.com/facts_7597003_maytag-range-error-codes.html
Codes "F0," "F1," "F5," "F6," "F7," "F8" and "F9" are all various errors with the Maytag electronic range control, or ERC. The errors are various faults with the ERC and a replacement part is needed for the range.
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) More info, let me know. Charlie
Jul 26, 2011 | Maytag MER5775Q Electric Kitchen Range
Displays "F7" and a continuous
If your Maytag range displays the "F7" error code, it means that the programmed fault error 7 occurred with the range. Luckily the error is easily fixed in most cases and requires no new parts.
Identification:
Once the error appears on the range it is usually followed by seven loud beeps to represent the number. Clear the error by holding a button down for a minute. The LCD will flash and the code will disappear.
Effects:
The most common cause of the "F7" error is a stuck button on the LCD panel. Look around the range control panel and examine to see if any buttons appear pushed in, stuck or out of place.
Prevention/Solution:
Take a damp rag and light wipe around the buttons to clear out any grease, food particles or sticky substance that may have built up around the button. Attempt to use your range and see if the error appears again.
Considerations:
If the error continues to appear, there could be permanent damage to your electronic range control. Contact your Maytag dealer for warranty information and replacement parts.
Keep us updated.
May 24, 2011 | Kitchen Ranges
Fault Code "F7"
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Maytag CWE5800A Electric Double Oven
I have a GE Range model JBP85. I have an error code F7. It appears the clock key is stuck. Is there any way to unstick this or any other key? The key pad is expensive to replace.
Hi, Error F7 on your oven means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC).
Oct 23, 2010 | GE JTP15 Electric Single Oven
Maytag Electric Ceramic Glass top stove
You can replace the failed component which is either the burner or the switch that controls the burner. A voltage test would have to be done to determine which compoonent has failed. Generaally it is worthwhile to repair the range.
Apr 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
MAYTAG oven flashing f1 and f7?
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 21, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag stove with f7 code
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Dec 19, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
292 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
