Question about Bosch Dishwashers
The timer on my dishwasher is really off. No
The timer on my dishwasher is really off. No matter what wash I select (REG/Quick) it takes over 2 hrs to clean. I jumps from 1 min. left to 11 or from 136 min. to 28 then back up again. What can I do to fix it?
Tara
  • 22 Answers
The best thing to do is replace it ... but make sure all the connectors are in place
Posted on Nov 14, 2009
Run cycle
Sounds like the timing mechanism is messed up, call the repair place and see if they can fix it. other wise take the front panel off and see if you can adjust the dial that controls the timer.
Jan 09, 2008 | Maytag 24 in. MDB5600A Jetclean II...
So far top drawer takes too long .Been washing over 2hrs
Please check the flow of the water to the inlet pipe connection, check the filter at the inlet and also the inlet valve. If there is a slow water flow it will take much longer for the cycle to finish. Also try with other programs specially short/quick programs .
It will also be good to check the pump pressure and the sparying arms.
Nov 22, 2011 | Dishwashers
Got a used kenmore elite and I am looking for an instruction manual. I need more info on the washing cycles. Does it normally take 1 1/2 hrs to wash on the quick cycle mode? Model # 665.17483300 Type...
Here's a link to your model, showing exploded diagrams and parts lists, for future reference.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66517483300/0582/0130000?pathTaken=&prst=0&shdMod=66517483300
And your manual.
http://www.managemylife.com/mmh/owner_manuals/10240/KENMORE-Dishwasher-L0308215?brand_name_search=665.17483300
I found similar Kenmore dishwashers on Consumer Reports with around 135 to 145 minutes for a normal wash cycle and around 5 to 6 gallons per wash. A quick wash would take somewhat less, depending on the model. But not much less. I think you are OK. Because dishwashers are using less water these days, they count on longer wash times to produce the same effect.
Best regards, --W/D--
Mar 11, 2011 | Kenmore 24 in. 17483 Built-in Dishwasher
How to program a intermatic outdoor timer/photo control hb51rc
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
1. Turn dial selector to the "off" position and
plug timer into three conductor outdoor outlet.
2. Turn dial selector to timing interval
desired (i.e., 2 Hrs, 4 Hrs, 6 Hrs, 8 Hrs,
dusk to dawn, etc.).
3. Plug outdoor lights into Easy-Set™ Timer -
lights will turn on automatically at dusk.
4. Lights turn off 2 4 6 or 8 hours later
depending on dial selection
Dec 07, 2010 | Intermatic Outdoor Timer/Photo Control...
Takes 2 hrs to run a 45 min cycle
defo a heating element fault or an ntc fault. More likely to be the element though.
Mar 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
The most obvious failure would be the mechanical timer that is behind / part of the knob used to select the cycle.
But, you may want to inspect the heating element in the sump area -- some dishwashers will wait (and wait) for the water temp to come up high.
Good Luck!
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Stuck on wash cycle
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
Aug 05, 2008 | Kenmore 24 in. 15079 Built-in Dishwasher
Changing the cycle time
sorry, but you are not exactly clear. Timer is pre programed to the program selected. the lighter the wash the less time it will take.
May 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
75 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
