Question about Samsung SyncMaster 913V 19" LCD Monitor
Monitor syncMaster 913v wont run 1280 1040 Resolution has in past goes blank moving "box- message' says ajust to 1280 1040 resolution Runs on other resolution settings ok
    Problem Solver:
  • 19 Answers
Dear
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor to the nearest samsung's service center.
Best regards
Posted on Jan 17, 2008
I am getting an error message Not Optimum Mode Recommended Mode: 1280X1024 60Hz on my Samsung SyncMaster 913v monitor, what do you recommend to stop this message from occurring over and over again
If you are in windows, right click on your desktop in a blank area. On the drop down box that shows, click on Screen resolution (For Windows 7), properties (For Windows XP), or personalize (For Windows Vista). From there navigate to any tab or menu option to change video settings, or screen resolution.
There should be a slider bar to change the resolution you have, slide it to the 1280x1024 option and click apply.
I have included a video to assist further if I did not explain well enough.
May 23, 2011 | Computers & Internet
My Samsung SyncMaster 913V (Black) 19 in. Flat Panel LCD Monitor, does not work correctly. Every time I reboot my computer the screen only works for a few seconds and after that it gets black and a...
Resolution setting of computer is not compatible with spec on monitor. Adjust computer res setting to agree with monitor and you will be good to go. If settings are ok then the issue lies within the innards of your monitor.
Apr 15, 2017 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung Syncmaster913v Monitor. The screen is totally black, but when I remove lead from computer it shows "Check Signal Cable" in colour. Also when I press Menu, in top left hand corner...
If the color still works, and it works on other computers, there is something wrong with the computer in question. But this is not the case, so logically, something is wrong with the monitor. Check the cable for broken pins.
Feb 11, 2011 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung syncmaster 913v gives message ' not optimum mode"
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
My syncmaster 710n is not working. I get the box where it ses what resolution si the right one, but the syncmaster 710v works normaly. Does that means my 710n can`t be repared anymore? Thanks
Not completely sure what you're saying. Here's what I got out of your problem:
You have a Syncmaster 710n that displays a box saying the best resolution is _____ x _____, but your Syncmaster 710v doesn't show that message.
The main question I have to ask you is whether or not you see the screen or display behind the message on the Syncmaster 710n.
In either case, I doubt that this is a hardware problem. I also highly doubt that your monitor cannot be repaired. Try the following:
1) If you see the display/screen is showing behind the message box, this is almost definitely a setting issue. You need to press the menu button on your monitor and look for an option that says something like "display resolution message" or "ideal resolution message", or something else like that. Then you need to change the setting for that option, for example if "Yes" is selected, then you need to change it to "No" or if "Enable" is selected you need to change it to "Disable".
If you have the manual for the monitor, it should make it easier to know what setting to change. If not then go here:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=710N&prd_ia_sub_class_cd=P
and download the Manual that you need.
2) If nothing is being displayed behind the message, try to change the display settings of your computer. While using a different monitor, try the following: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution to something compatible with your monitor (like the one it suggests you to change it to). If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know how it goes.
Feb 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Cannot set my SAMSUNG SYNCMASTER 710V MONITOR RESOLUTION
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
Aug 22, 2009 | AOpen Black 17" CRT Monitor
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Resolution Issue "Not Optimum"
Hi Guys.
I have had this problem and after a bit of searching found that it is a known problem.
Give Samsung a ring and if it's in warranty they will replace it
Jan 03, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 913V 19" LCD Monitor Logo
372 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
