Question about Frigidaire Freezers
I am trying to find a wiring diagram for my M1
I am trying to find a wiring diagram for my Frigidaire M1 5303918277 218699501 icemaker housing unit.
How can I find a wirning diagram for a ice maker that has guit making ice but the pump will run?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Your Ice machine does not have a wiring diagram. I have repaired many of these.
1.) Are you getting water? If not it is your pump.
2.) Reach in and feel the cold plate. Is it cold? If not you have a refrigerant leak.
3.) The problem may also be within your main control board.
Unless you have a current service contract these units are considered throw-always. It will cost you twice as much, if not more, to repair it than what you purchased it for, assuming you call a service company.
Go into the following website. Plug in the first 5 numbers on your model number and a list of model numbers will appear. Your model number is incorrect.
Select the model number then click on parts and you will get diagrams of your icemaker. Water Filters Lawn Garden Appliance Parts
Mar 21, 2015 | KitchenAid 18" Ice Maker - Black
Why is icemaker not working
Good Morning Friend,
I understand the ice maker is not working in your Frigidaire refrigerator, model# FPHG2399PF. Please follow these steps to resolution:
    1)Make sure the ice maker power switch is on. This button is located on the ice maker itself.
    2)Make sure there is not a small cube caught in the ice maker itself. If there is, carefully remove it.
    3)Check your water filter. Water filters should be changed roughly every 6-8 months. Also make sure your water filter is seated correctly. Try taking out the filter and re-installing it. Listen for 2 clicks and make sure it is flush with the water filter housing.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 21, 2014 | Frigidaire FPHG2399PF Professional 23 Cu....
Mfu14f3gw2 wiring diargram
Good Morning Jon - The best way to locate a Wiring Diagram for this particular unit, MFU14F3GW2 is by visiting the manufacturer website. The Owner's Guide and Parts Manual are also available. Hope this information is helpful and if there is anything else that I can help you with, please feel free to reconnect!
Jun 09, 2013 | Frigidaire Freezers
Icemaker in freezer is draining too much
Hello georginalemo - Sounds like the unit has a possible leak. Consult a professional to move forward accurately and assist with the repairs.
Feb 04, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire ffu1767fwo (power spike) does not turn on can it be fixed
Hello tom97420 - Was the freezer unplugged during the power outage? It is best to be unplug unit and wait for the power to come back on, turn control to off, plug the unit in and reset control to factory suggested setting. Do not open freezer door unnecessarily if freezer is off for several hours. Make sure the freezer plug is tightly pushed into electrical outlet and not plugged into a GFI. Is the temperature control in the OFF position? Set temperature controls to proper setting suggested by owners guide or set to the halfway point and adjust it up or down as needed. If any suggestions are ineffective, contact a professional to move forward accurately. From what you have described the power loss could have possibly caused a communication problem with the control board, temperature control or wiring harness.
Oct 24, 2012 | Frigidaire 16.7 cu. ft. / 473 liter...
Frigidaire icemaker wont fill with water. Side by side model. The icemaker motor is working but water is not filling in to make the ice.
Take a blow dryer and try to thaw the tube out. It may have froze on you. Please leave good thumbs up for my guess Thanks The Raz Shack
Feb 20, 2010 | Freezers
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My Frigidaire side by side is not making ice. (Model GLRS267ZAW1)It goes through the cycle but no water is getting into the icemaker. I can pour water in to the icemaker and it makes the ice and dumps it....
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Oct 03, 2009 | Freezers
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
Freezers Logo
133 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
