Question about Bosch Dishwashers
I just installed a Bosch SHX43P12UC Dishwasher makes a sound but
all. It's not getting water. Is there a plug in the water input on the washer that need to be removed?
  • 22 Answers
Water line to solenoid valve...try checking for voltage...or the water might not be turned on
Posted on Nov 14, 2009
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
No water is getting inside my Bosch dishwasher compartment. Water supply to dishwasher is ok. Checked hose at input of dish washer and water supply is ok. Could pump have packed in? Model 004 920 378....
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Bosch Dishwashers
The dish washer runs but does not pump the water out sounds like the pump is runing and nothing seems to be plugged
Dec 31, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher SHX46A05UC/23 - No Water
Sounds like your recirculating pump is clogged If it is water can't get up enough pressure to turn the sprayers.
You'll need to start pulling parts out of the bottom inside to get to that pump. I don't work on a lot of Bosch, but that sure sounds like it to me. I see this a lot. Hope this helps...
Nov 28, 2009 | Dishwashers
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Cold water. Water has never been hot since installed.
indicates that the heating element in the unit is non operational ( not connected or burnt out )
Jul 30, 2017 | Bosch SHU5316UC Dishwasher
Dishwasher wont fill.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Sep 29, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch SHV 4303 Dishwasher not draining
change your water pump or belt . Also make sure that no one just changed the garbage disposal and did not take the plug out of the disposal housing before installing the washer drain.
Good Luck
TEETERMAN
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch built in dishwasher won't drain
1.
  1. Adjust the level of the washer to mitigate sound.
  2. The water backup is due to the low drain hose mounting position. Check the sink disposal position; the drain hose connection from the dishwasher to the disposal must be placed higher than the present drain hose passing the sink cabinet from your dishwasher.
Jun 24, 2008 | Bosch SHU3305 Dishwasher
My Bosch Dishwasher doesn't run
double check power to your plug socket ( use bedside lamp)
check fuse in plug
check water supply ( run the water supply directly into pot/bucket)
make sure door closes properly (if built in )
if built in remove and then check!
Feb 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
131 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
