Question about KitchenAid Ovens
Kitchenaid kemc308kss01 probe light wont go off
  • 1 more comment
  • raubel Nov 14, 2009
    The probe symbol stays lite and beeps with no probe in oven . Will not shut off
    Probe light on kitchenaid kemc308kss01 stays on and beeps with no probe inserted. any fix ideas
    I will run with this. First time user so I didnot think I was talking to a human. Sorry, you did a fine job. Rob
  • KitchenAid Master
  • 19,396 Answers
Hi.
Try first disconnecting the power cord or tripping the circuit breaker for two minutes to reset the oven.
If that does not clear the error, then the temperature probe must be tested and eventually replaced.
The temperature probe is tested removing it from the oven cavity and touching with the terminals of a multimeter set at Rx1 its contacts to read impedance.
At room the probe must have low impedance, about 1.1KOhm.
If the probe has no continuity (circuit open) , then the probe must be replaced.
Here the probe: PS1156355
Probe is part 14 on diagram below , click on the picture to enlarge.
Here all parts and diagrams for your appliance.
Please do not forget to leave feedback.
Regards.
G.
Posted on Nov 14, 2009
  • Ginko
    Ginko Nov 14, 2009
    Hey!
    I spent 15 minutes to find parts and diagrams, and to describe the fault, testing and repair, and I received a bad vote!
    Now that I am voted out the question will be passed to a different expert.
    Good luck.
  • Ginko
    Ginko Nov 14, 2009
    If the oven is asking insert probe, that is because of broken wiring to probe.
    I am writing in a hurry because question will be relocated.
    Have wiring harness to probe holder replaced, that is the other probe, not the temperature probe.
    Here more on thishttp://www.applianceblog.com/mainforums/...
    goodbye.
    G.
  • 10,515 Answers
Take it out and the re insert it back in do this with the power off and see if that works switch your breaker off when you do this.
Let me know, once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Nov 14, 2009
    Thanks for your response!!
    That's absolutely perfect. We want that you should be 100% satisfied from the Fixya Service. Let me know, once you check and do not forget to Accept the solution, once your problem would be resolved.
    Thanks!!
My kitchenaid temperature probe won't turn off
If you mean the probe icon will not leave the display, you need to be sure the probe jack is not coated with food residue that is grounding it, if it is clean- send the control in for rebuild. Help Me Find My Model Number RepairClinic com
Feb 24, 2015 | KitchenAid Ovens
The probe light is on as well as the question remove probe or enter probe temp. This will not go away. We never used this option. We turned breaker off for 10minutes or longer... Pushed some buttons .
Make sure there is not food residue on the probe jack, it will ground the jack and make the control "think" the probe is in use. You can also send the control in to be refurbished... the solder joints on all of these machines are failing badly by now...
Oct 09, 2014 | KitchenAid Kitchen Aid KEBS277SBL Double...
Kitchenaid KEHC309 -oven stops working just after starting, and 'insert probe' warning appears. I ran a cleaning cycle to remove any moisture from the oven, but that did not solve the problem. My oven is...
I had another brand with that fault from new. We disconnected the probe wiring from the control board and it stopped looking for it.
Also, could be a setting has been changed inadvertently.
Oct 14, 2013 | KitchenAid Architect® KEBS277S Electric...
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
How do I use the thermometer in my Kitchenaid Superba?
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is: http://shop.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10162223.pdf
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
Dec 05, 2009 | KitchenAid Architect Series KEBC107KSS...
KEMS377 Lower electric Convection Oven - no probe, won't work!
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Aug 07, 2008 | KitchenAid Architect® KEMS378S Electric...
Ovens Logo
207 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
