Question about Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
How do we get proper timing with a honda gx160 5.5
    President:
  • 583 Answers
The v on the camgear goes to the dot on the crankshaft gear, then slide the cam shaft in . it is now tmed. when you get to the tappets inlet .006 exhaust .008 any queries come back to me .
Posted on Feb 04, 2010
2 Suggested Answers
  • 583 Answers
SOURCE: what are the timing marks for honda 5.5 gx160
they are marked on the gears arrow goes to dot
Posted on Aug 08, 2009
Honda trx350fw will not start i have spark and fuel still nothing
There only three things a good engine needs to have to run:
1. Adequate compression
2. A properly timed spark
3. The proper air/gas ratio - delivered
.. one of these is missing...
Jul 24, 2017 | Honda 2005 TRX 400EX
98 Honda civic that cranks but want start now. I had to replace the water pump. When I finish it would not star. I replaced spark plugs and wires same problem
The timing belt needs to be retimed properly after this repair.If the timing procedure was not performed properly it will not start and chances are if this is the case, valve damage may have occured
Mar 02, 2016 | Honda Cars & Trucks
How do I fix my timing on a 91 Honda prelude with the distributor cap n no timing gun
You cannot properly set static timing on any vehicle without using a timing light. Buy or borrow a timing light.
May 06, 2015 | 1991 Honda Prelude
My 1992 honda is due a timing belt change.will changing the belt will it go out of timing. Thank you. robert
No it will not affect the ignition timing as long as the belt is properly installed..
May 20, 2011 | 1992 Honda Accord
The maitenance light flashes ten times on my honda accord 2001 why ?it only happens when i start my car.
if u r not maintain ur car properly or ur car require proper maintenance that why light flashes ten times k
Apr 29, 2010 | 2001 Honda Accord
Honda engine won't crank not firing properly
If you mean it turns over (cranks), but won't start... Get a timing light, and hook it up. Aim the light at the marks on the crankshaft. If they are jumping around, i suspect you'll need a timing belt.
Jan 28, 2010 | Honda Civic Cars & Trucks
How much to fix ignition timing on 94 honda accord
to properly replace timing belt, water pump "which is driven by timing belt" and seals probably between 350.00 to 450.00 maybe 500.00 at the most
Dec 03, 2009 | 1994 Honda Accord
Ignition timing on 1990 Acura Legend.What is the proper procedurw for checking and adjusting the timing?
properly connect a timing light aim it at the marks on the flywheel or crank pulley disable timing advance and turn the distributer until the timing mark lines up with the zero mark
Sep 23, 2009 | 1990 Honda Accord
Need to tighten the timing chain
It has an automatic cam chain tensioner. If you are getting cam chain rattle, I would look at worn guides/chain.
Jul 22, 2009 | 1996 Honda VT 1100 C2 Shadow Sabre
2001 honda civic changed timing belt and now the car starts and dies shortly after
double check that the timing marks are lined up properly and make sure if you unplugged any wires you plugged them back in properly
Jun 22, 2009 | 2001 Honda Civic
Honda Quincy 17 - Gallon  Air Compressor with 5.5 Hp - G15H17PC3B Logo
719 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
