Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
Orange glow coming from inside freezer back of freezer warm
  • 6,784 Answers
HI. that glow will be the defrost element. If that element continues to glow for a long period of time, longer than an hour, this will indicate that there are issues that concern the integrity of the defrost timer, or adaptive defrost control board. I would advise to shut off the power to the unit for five minutes. this will rest all the control boards that exist in the units structure. re-introduce the power to the unit, after the five minutes are up. If the element continues to glow, continuously, this will confirm that the defrost module has failed.(stuck in the defrost position). replace the either the defrost timer, or adaptive defrost control board(depending on the model), if the reset did not correct the issue.
Posted on Nov 14, 2009
  • GE Master
  • 1,606 Answers
The orange glow is normal as is the heating of the rear panel . Your refrig is in the defrost cycle . Stays in defrost for 28-32 min , although the heater will cut off before that time , due to the defrost thermostat . This should happen every 8 , 10 , or 12 hrs , depending on the model of the refrig .
Posted on Nov 15, 2009
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
My freezer is turning bright orange in the back like it is on fire and it is only 3 months old. The inside back wall of the freezer is hot. Is it catching on fire?
The glow you are seeing is just the normal defrost cycle...every once in a while the refrigerant system will shut down and a heater will melt the ice off of the cooling coil...this is normal operation and there is no danger!!
heatman101
Sep 10, 2011 | GE Americana 15.6 Cu. Ft. Top-Freezer...
Unit is a Jenn-air JRSD209T. Two problems. When water runs to fill the ice maker it runs down into the ice shoot leaving you with a cup of water with your ice. Second problem. Witnessed a red glow...
For your first problem i need a bit of a clarification. Is what your saying,when you dispense ice through the door some water also comes out of the dispenser??
For the glow that is perfectly normal,what your seeing is the glow of the defrost heater melting off the biult up frost. If it did not come on and melt the frost the refrig would not be cooling.The term"FROST FREE" is a bit misleading. Their is automatic defrost refrigerators such as the one you have, and the manul defrost that you need to defrost manually every month.
Gene
Aug 12, 2011 | Jenn-Air JSD2789GES Side by Side...
Glowing orange from inside back of freezer
how do you think the fridge defrosts,there's a heater in there
Oct 19, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Our Smeg SR640XA side by side refrigerator is making strange puffing noises at the bottom section of the freezer. It puffs four or five times and then it sounds like something is dribbling in the back of...
It is the defrosting heating elements and sensors that has gone bad.
Check for glowing light at bottom of the back panel. Turn the freezer section off and contact Smeg!
Mar 14, 2010 | Smeg FA561X Side by Side Refrigerator
We have a TFX25JR side-by-side with ice maker and water dispenser; had water leaking on floor on freezer side of bottom left corner. Comes under tray, cleaned the coils and seemed to work, but 2 weeks...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Orange glow in freezer, what is it?
Your refrigerator is a frost free unit. The derost cycle in a refrigerator is controlled by a timer or an electronic control. When a unit goes into defrost, the fans and compressor are turned off and a heater in the freezer is energized. This is the glow that you see, and the hissing sound is the water droplets, from the melting frost, making contact with the heater. This is perfectly normal.
Apr 27, 2009 | Refrigerators
Glowing light and warm air freezer side
HI thanks for your question. you found your freezer in a defrost cycle, which is normal function.the defrost cycle happens every day every 10 hrs. on for about 20 min. then resumes the cooling cycle. so its normal. thanks the appliance doc, please rate my answer. thanks.
Oct 12, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Takes to long to Preheat
the burner element iside the oven(the rod that glow,s orange) is burned out,even though it glows and the oven is warm,the element is worn out and has to be replaced,unplug the oven,shutt off gas supply to oven,pull off back cover youll see the rod coming thru each end of the rod will have 1 wire unplug the wire off the clip,go back to the inside the oven follow the rod to the back youll see 2 screws holding the rod unscrew and pull rod thru,easy job and elements arent exspensive,but make sure to unplug oven,and shut off gas
Jul 09, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Orange light in the lower part of freezer
pants, don't worry about this, your refer was going into defrost. When this happens, the defrost heater turns on to melt the ice off the evaporator in the freezer comp. Last's about 20 minutes and sometimes you can see the glow and hear the ice hitting the heater...Catriver.
Jan 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
1,650 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
