Question about 2wire (1000-400108-001) Router
2wire router The only way i can access the web through any browser is in safe mode. I have a connection and can access email and my other computer on same router works fine. Something is happening during startup that does not allow the router to work on this computer windows xp. Have tried ie6, ie7, foxfire
  • riders343 Nov 27, 2008
    I can only connect in Saft Mode as well but also works with https, just not http. Did you find a fix back in January?
    Scholar:
  • 64 Answers
Sounds like a firewall on either your comp' or the router isn't enabling you to access the net. Try changing the settings, I would check the router's firewall first.
Posted on Jan 08, 2008
How do I get my samsung bluray player to connect with my AT&T uverse 2wire router through PBC(WPS)?
login to your 2wire router using a computer that is connected , open a browser and type 192.168.1.254 on the address bar, once logged in look for wireless setting you'll find WPS setting /button click on that then push the WPS on your bluray player this needs to be done within a few seconds for the router and the bluray player to pair.
Jul 12, 2014 | 2wire Wireless-G 802.11g ADSL Gateway
Where do i put my activation code
You have to connect to your 2Wire box through a web browser (gateway.2wire.net) And once you're inside the configuration page of the 2Wire, you should see the "key code page" to enter your activation key code.
Feb 15, 2013 | 2wire (1000-400108-001) Router
Unable to connect to home ATT 2wire with new Belkin USB wireless
AT&T 2Wire routers function as both routers and modems. You can disable the router functionality by placing the router in bridge mode. In bridge mode, the 2Wire device functions only as a modem and forwards all incoming traffic to the device behind the 2Wire router. For example, you can use a different router instead of the 2Wire's built-in router by enabling bridging mode -- the router behind the 2Wire device will get the external IP address, and the 2Wire router won't interfere.
Step 1Type "Homeportal/management" (without quotes) into your Web browser's address bar and press "Enter" to access the Management page in the 2Wire router's Web interface.
Step 2Provide your 2Wire router's custom password, if you set one. The router comes with no password set.
Step 3Click "Configure" under Broadband on the Management page.
Step 4Type a period (".") into the "Disable PVC Search" box.
Step 5Set the value of the "VPI" box to "0" and the value of the "VCI" box to "35".
Step 6Set the "Connection Type" to "Direct IP" and click "Submit."
Step 7Click the "Configure Services" link on the Management page.
Step 8Uncheck "Enable Routing" and click "Submit."
Jan 31, 2013 | Computers & Internet
Where and how do i find my access point I'am trying to set up a wireless internet connection
Hi Kregerbc,
If you want to know your Access Point it is the Name of your Network or Network Key (SSID). Usually the Network Name of 2wire router is 2WIRE and the Last 3 digits of the Serial Number of the Router. The Serial Number is located at the side of the router you will find a Sticker and look for the Serail Number you can also see there the Wireless Network Key under the Bar Code. Another Procedure to find the information of the router is to access it. listed below are the steps on how to access the router.
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your Wireless Connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
Rate me if this helps so i can help others
Thanks for using Fixya.
Feb 04, 2011 | 2wire (2701HG-B) Wireless Router
Connected a 2wire adapter, downloaded driver, but does not connect to my dlink n router, I have 3 other computers in my house all wireless that has no problem connecting, is this a 2wire problem or is it...
Make sure the N router is also sending a broadcast for B/G mode, as the 2wire adapters do not support N technology. You can login to your router by typing "home" or "192.168.0.1" or "192.168.1.1" in your web browser and check the wireless settings on your Dlink to see if it supports these methods.
May 16, 2009 | 2wire (1000-100009-001) Network Adapter
Trying to access my 2wire router
Please try the following:
1. Check the ip address and default gateway on the computer by typing ipconfig in command prompt.
2. Try to ping the default gateway from the hardwired computer.
3. If you are able to ping the default gateway, but not able to log in, Delete Cookies and check if you could log in.
4. If you still could not log in, try from another web browser.
Mar 31, 2009 | 2wire (1000-400108-001) Router
Connecting 2wire modem./router to extra linksys router
to get this right you must make sure that the 2wire will be configured to be your gateway which means that the 2wire itself will be connected to the internet then set the linksys to DHCP mode because if you dont it will give you a router behind router error , make sure that the 2wire is properly authenticated and connected to the internet to make sure access the gui by typing gateway.2wire.net on your browser and run system set up wizard
Dec 11, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Homeportal 1100
If you connect with an ethernet cable, you don't need any additional drivers at all. You just need to have a browser connected to »192.168.1.254/ and a product key. The 2Wire has a built-in wizard which you can access with the browser, and it will guide you through the setup. The product key is obtainable from a number of sources, including the 2wire web site, although you should look to your ISP's web pages first if they provided the 2Wire.
If you don't have an ethernet adapter on your computer, you might want to consider purchasing one of those inexpensive ethernet cards. Ethernet seems to have a lot fewer problems than the USB route.
Jan 05, 2008 | 2wire (1000-400108-001) Router
2 wire
power up the 2Wire and your computer, and open any web browser.
The 2Wire on first boot up automatically directs your web browser to its builtin (page=SBC_GL_welcome2) welcome/setup page if not :
Start a web browser - all 2Wires can be accessed with just http://homeportal or
http://192.168.1.254 or
http://172.16.0.1
Nov 25, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire (1000-400108-001) Router Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
