Question about Frigidaire FEF366 Electric Kitchen Range
Frigidaire Electric Smoothtop Range PLEFZ398EC
A code F7 keeps flashing. I turned off all the knobs and five minutes later I'll get the same code.
  • Anonymous Mar 28, 2014
    I need the knob decals for thermostat and burner knobs.
How do I replace the burner on my smooth top range?
Posted on Jan 11, 2008
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
F7 keep frashin on the range
Good Morning Marlon, I am happy to assist you. Typically error code F7 indicates that there is a failure with either the potentiometer or UIB (User Interface Board). Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is important to wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further to ensure the appropriate replacement part is order and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Aug 08, 2013 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire FEF336BC Electric Kitchen Range F7 10
The "F7 10" fault code implies the left front potentiometer/left front burner switch is open and will need to be replaced. Here is that part to order.
Mar 31, 2013 | Frigidaire FEF336BC Electric Kitchen Range
Range led flash code F7
Here is the error information for Fault Code F7
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Hope this is helpful, I will also provide you a link to to a helpful site.
http://www.applianceaid.com/fault_codes.html
Mar 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
F7 code and beeping
in version 1 of your model, F7 requires the replacement of the EDC (electronic door control)
in later versions F7 requires the replacement of the EOC (electronic oven control)
Feb 01, 2009 | Frigidaire PLEF398AC Electric Kitchen...
F7 screens flash and beep,but not every time we use range
There's a lot of info missing here, but any tech should be able to tell you what the F7 indicates. Each F code indicates a specific problem. In my case, an F-1 indication which says the circuit board has a problem, was resolved easily by fixing a problem with the momentary contact convection oven switch. You may have a faulty switch like that which could be causing the problem--in all likelihood, it was NOT a circuit board problem. If it was, then it was caused by another problem somewhere else, and they owe you a new circuit board, and a repair on whatever is causing the circuit board to fail. But more than likely they owe you a refund for the board you bought, and a fix on whatever is causing the problem....
Jan 29, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire cooktop beeping f7
Hi Bobbiflower,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model # and download the manual.
if you can not locate the answer in the book,
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Jul 19, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire cooktop
Hi Bobbiflower,
Happy to help you!
1-800-905-9505
They answer 24/7
Thank you Neil
Jul 17, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire Electric Smoothtop Range......getting F 1 error on digital display
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jul 15, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire FEF366 Electric Kitchen Range Logo
291 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
