Question about Cell Phones
The icons on my iphone have become too big for the screen & I can't view the whole screen properly. It was fine until earlier today (i've had it a week). Tried tapping 3 times & does not work. Pls help!!
Just experienced it myself too, try using THREE fingers to tap the screen TWICE to reset and TWICE to enlarge again...
Posted on Jan 27, 2010
Posted on May 04, 2010
How do you delete photos/videos?
iPhone:
launch the Photos app, navigate to the Photos tab on the left until you get to Moments view. Then tap Select at the top-right of the screen, and tap each Select link next to each batch of images you want to delete. Tap the Trash button in the bottom-right corner, confirm that you want to remove the images, and they'll be deleted.
IDGYou can also delete images in batches from the iPhone's Moments screen."But hang on a second!" you might be murmuring in an exclamatory way, "I just launched the Photos app on my phone and there are still pictures there. What's up with that!?"
Ah, that would be your Photo Stream.
"And those photos are still taking up space on my iPhone, right?"
Well. Yes.
"And so we haven't really gotten rid of all the photos on my iPhone, have we?"
No. No we haven't.
"Sooo..."
Sooo you need to switch off Photo Stream on your iPhone. To do that go to Settings > Photos & Camera. In the resulting screen flick the My Photo Stream switch to Off. This will cause the pictures to disappear from your phone.
Android:
Delete Single Photo
  1. Open the "Gallery" or "Photos" app.
  2. Open the album that contains the photo you wish to remove.
  3. Tap and hold the photo until a trash icon appears at the upper-right portion of the screen.
  4. Tap the "Trash" icon located at the upper-right portion of the screen.
  5. Confirm your selection by tapping "OK" (Gallery) or "Move to Trash" (Photos) and the photo is deleted.
Delete Multiple Photos
  2. Open the album that contains the photos you wish to remove.
  3. Tap the "Menu" icon located at the upper-right corner of the screen.
  4. Choose "Select item" (Gallery) or "Select..." (Photos).
  5. Tap the photos you wish to remove. They will become highlighted.
  6. Tap the "Trash" icon located at the upper-right corner of the screen.
  7. Confirm your selection by tapping "OK" (Gallery) or "Move to Trash" (Photos) and the photo is deleted.
Delete Entire Album
  1. Open the "File Manager" app.
  2. Navigate to the location where the photo album is located. You can usually find them in the "DCIM" or "Pictures" folder.
  3. Tap and hold the folder you wish to remove.
  4. Select "Delete".
Aug 06, 2017 | Cell Phones
Iphone won't start up
Un plug the battery check the connections on the battery and the iphone clean with some stochbrite and wipe off with 90% alcohol let dry and should work fine as long as the battery is fully charged.
Dec 26, 2012 | Apple iPhone 3G
The icon's was too big
Go to settings >> General >> Accessibility and turn off everything..
Apr 13, 2011 | Apple iPhone 3G
The screen icons are very big now and i am not able to make them normal
Your iPhone is in enlarged mode caused by accidentlally double tapping with 3 fingers. You can find the solution here: iPhone screen enlarged.
Jun 28, 2010 | Eforcity Apple iPhone 3GS 16GB / 32GB...
Big icon on iphone
This sounds like the phone is not booting properly. Is the background black with a big Apple icon on the screen? If so connect the phone to your computer and open iTunes. hold the power and home button for 10 seconds until the icon disappears, then release the power button but continue to hold the home button until windows installs the driver.
This will put your iPhone into DFU mode, the screen should remain blank but the phone should be recognised in iTunes. Using iTunes click restore and the software should reinstall and resolve our problem.
Warning: All data on the iPhone will be lost and replaced with the last backup iTunes made.
Hope this helps, www.PuterCare.com
Jun 11, 2010 | Apple iPhone 3GS Black (16 GB)
My iphone is acting weird. Every screen is moving around a bit. I didn't do anything to it it just started today.
Well if it looks like the icons are "wiggling" than you just have to hit the home button and that will go away. If this isnt the problem i would suggest a soft reset. Hold your power and home buttones down until the screen turns off, then keep holding. The apple logo will pop up again if done correctly, once you see the logo you can release and your iPhone will boot properly.
May 10, 2010 | Apple iPhone Smartphone
Screen icons big
Try tapping the screen three times with three fingers! This may help
Feb 04, 2010 | Apple iPhone 3G
I got a permanent expanded screen, how do i fix that? my niece was playin my iphone 3gs and all of a sudden the whole screen permanently expanded, even the home screen, i can't even open up all the...
I got the same problems (3Gs screen Expanded); but resetting by depressing "Home" & "power" Button dosen't help.
By trail an error...I got the screen back to normal. Below is the solution.
Try this: "use 3 of your finger tips, tap the screen 3 times (like tripple clicking with 3 finger tips) on the Iphone Screen"
Done ???
Dec 17, 2009 | Apple iPhone Smartphone
Iphone 3gs the icons are very big and i cannot change them back
I ve had the same issue today and freaked out thinking the phone was crasing. How ever after spending 3 hours trying every thing and aking on the web.
when you double tap the screen it normaly zooms?? yes
use 3 fingure tips to do a double tap!
this will take a sort off large zoom screen lock off and bring the main screen fuctions back inline for you.
please let me know or leave a reply
:0
Jul 28, 2009 | Apple iPhone 3GS Black (16 GB)
Cell Phones Logo
1,501 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
