Question about Panasonic NN-T888S Convection/Microwave Oven
No power. I changed fuse but microwave blows it immediately.
Unit stopped working completely. Not even the clock. I found a 15amp 125v fuse inside the cabinet (right rear) Replaced that and bake/broil works fine, but microwave blows the fuse immediately. Any thoughts? This unit has only had about five hours of use total, but is three years old.
    New Friend:
  • 24 Answers
Be very careful! Standard microwaves have 2100volt capacitors and commercial ones 4000 volt capacitors.
*Decharge your capacitor(s) before doing diagnostics*.
You are now testing the high voltage side (as it works on convection). The main components are a transformer, a capacitor, a diode and a magnetron (havent seen a triac in a panasonic residential). If you have a proper meter that can test uf, decharge the capacitor, then test the capacitor, if it reads 0, you need a new capacitor (10$ used typically, 14$ new from ebay). To test the magnetron, decharge the capacitor first, remove the spade connections, test each leg to the frame of the microwave... if it shows measurable resistance, the magnetron is bad. The transformer is not something you test as I personally dont have a 4000 volt meter. If the diode, the magnetron and capacitor are okay, then the transformer is bad. To eliminate any other function, disconnect the low voltage to the transformer run a micropower cycle and check the fuse.
Hope that helps. My first instinct is the capacitor.
Posted on Dec 19, 2009
Suddenly microwave stopped working
(would really like more info- digital number dead as well?)
(assuming completely dead) Could be a couple of things:
- blown fuses (inside, relatively easy to replace, std size avail at Raioshack) <-- most likely
- cut/loose power cord connection inside.
- (unlikely but worse case scenario) Door was closed crooked- one tong hit one door switch before the other- causing a short circuit internally that "self destructs" the microwave to prevent it ever operating with an open (or even crookedly ajar) door, irradiating any users. Typically it just blows the fuses, but if fuses blow immediately upon replacing and turning power on, then possibly one of the switches fused or melted internally, and needs to be replaced.
Jan 28, 2014 | Whirlpool MT4155SP Microwave Oven
No power
i had the same problem and did what this fella suggested and worked just fine. There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. If the model number you listed this question under is correct, the line fuse is connected in line with the power cord inside the unit and is listed as part of item 4 in the parts listing (part number STD384200).
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
Feb 06, 2012 | Emerson MW8102SS 1100 Watts Microwave Oven
My unit has completely and suddenly died. Nothing works: heat, turntable, clock, light, all dead. There is power in the outlet, which tells me that there may be a breaker or fuse inside the unit that has...
Replacement parts can be ordered at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer competitive pricing, so shop and compare. The first three sites on the list also inlcude exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If the model number you listed this question under is correct, the line fuse is connected on the wiring harness inside the unit and is listed as part of item 14 under the "Interior" parts listing (part number 815174). There is also a Thermal Cut-Out (TCO) in the High Voltage network mounted on the magnetron that, if blown, will cause the same symptoms. It is listed as item 15 under the "Magnetron and Air Flow" parts listing. The part number is 815076.
CAUTION: DO NOT under any circumstances attempt to operate or troublehsoot the microwave oven with the exterior case removed. Voltage potentials in the High Voltage network can exceed 3,000 volts. Always UNPLUG the unit when attempting any repairs.
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for less than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Aug 23, 2010 | Whirlpool GH7155XHS Microwave Oven
This model just stopped working while heating food up. Now cannot get even the power to register when you plug it in. Is this doen for?
Jul 22, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Maytag 2 yrs old. Completely dead - like getting
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this wiring diagram at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
This model has TWO potential causes. The line fuse or the Thermal Cut-Out (Thermostat) for the Magnetron. The line fuse is connected in line with the power cord inside the unit and is listed as part of item 26 under the "Cabinet-Base-Cavity" heading.
The Magnetron Thermostat is listed as item 6 (part number 56001028) under the same heading. If you managed to overheat the oven any time recently, you may want to check the thermostat to see if it is still good. It should read 0 ohms when measured out of the circuit across the terminals.
May 24, 2010 | Maytag MMC5000 Microwave Oven
Is there a fuse or breaker inside this model.
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
The line fuse is listed as item 12 (part number 56001353). Keep in mind, there are different vairations on the model number you provided. You need to look at the model number you have and include the last three letters as well. I reviewed most of these models and they appear to all have the same parts. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended. If you wish to order on line, use the part numbers to search by comparison as the model number you listed this question under may not be available at all the websites I have provided. The parts, however, ARE listed.
May 13, 2010 | Amana AMV5164 Microwave Oven
It just quit while cooking. Is there afuse in this microwave?
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
The line fuse is listed as item 12.
Apr 27, 2010 | Maytag MMV1153A Microwave Oven
Not turning on has no power
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
The line fuse is listed as item 47.
You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
Apr 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hi, My microwave oven stopped working after I came home from four days of vacation. The digital clock works. What could be the problem? The turn table does not work. Is there any danger opening back of...
if the clock is working then the fuse is fine. if the fuse goes bad the unit would be completly dead. no their is danger removing back panel. as you said make sure the unit is inplugged., however some electrical parts inside hold a charge until discharged.the board could be bad, the door latch or switches could be bad.
Sep 19, 2009 | Sharp Microwave Ovens
Sharp R-930AK convection/microwave suddenly died
You need to open the oven (unplugged) by removing the screws along the case. Inside, there is a 20 amp fast blow fuse that you can get at Radio Shack. It looks cylindrical and white. I would test that first. However, replacing the fuse may work, but then, other components may have shorted inside causing the fuse to blow. Try the fuse replacement/test it first. Good luck
Apr 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Panasonic NN-T888S Convection/Microwave Oven Logo
615 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
