Question about Toshiba Satellite A105 Notebook
Laptop it appears i have no cd-dvd installed..when i put a cd its not recognized
  • 13 more comments
  • gio4unow Jan 08, 2008
    Im trying to use the installer cd to start over but it is not recognized...help me please
    I did that but when I highlight th enumber it appears only something like "default typr reg data (value not set..I dont see any filters
    when the cd is in nothing happens..when i open my computer it doesnt recognized the cd
    I did thta and it says that alll devices are working properly...????
    ok...i found that and I deleted them...restart and Illl wait...lets see
    nothing...it is not regnized...went to my computer,then to...error message comes it said d/ is not accessible ...because of an I/o device error....
    how do i set to slave>>>?where is the gray cable..?
    i did it ...nothing....can u repet again whats next..
    should I reboot after this bec nothing is hapennig
    no its not working...in the boxes it says the devices are working properly...1 and 2...???
  • gio4unow Jan 09, 2008
    i went back to theat number i highlighted it and now I dont see upper filter nor lower filter...since i removed them..no?
    is the re any chance or possibility that a virus erased something or that maybe there is a program like window media center thats interfering...?
    we have tried everythig but still cd and dvd is not working...I need help
    when u sy it appear in the pc..what exactly does it mean...because it is when i ry to open it that i have the error message that ays I/O device error
    but yes I can see the picture of the cd in y computer ,I can even order eject and it works..but doesnt open
    i restarted and repeat 1-3....it said found new hardware...new cdrom drive...it installed again..but nothing...to check the gray cable i shuld open the back of the laptop?...now what doesnt work
    how do u buy a dvd drive...? how much? where>>?
    Scholar:
  • 135 Answers
You can buy a DVD drive for your laptop for about $60 on eBay. I found 7 results on eBay.
Posted on Jan 09, 2008
  • 2,427 Answers
Hey how are you ,,
try this
1._ click start / right click my computer then click properties
2.) click on the hardware tab then device manager
3.) right click on anything on the tree view and click scan for hardware changes
4.)Click the + sign next to disc drives
5.)right click on your dvd and click uninstall
6.) restart your computer
7.) repeat steps 1 - 3
8.) id should find your dvd drive and reinstall it
9.) If that dont work buy a new dvd drive
LET ME KNOW HOW IT WORKS
  • 1 more comment
  • Rishi Roshan Ali Jan 09, 2008
    Io device error = INPUT OUTPUT ERROR, try what i suggested above and if it dont work get a new drive, the controll ic on this one may be damaged
    TRY WHAT I SUGGESTED please
    YOu can get it on amazon or ebay or the manugfacturs webpage. actualy any laptop drive will do, as its all the same..
    President:
  • 317 Answers
Remove the upper and lower filters from the registry
Upper/Lower Filters Fix
a. Click on Start --> Run --> and type in 'regedit' followed by the enter key
b. Expand the "HKEY_LOCAL_MACHINE" key (looks like a folder) by double clicking it (or clicking the "+" next to it.)
c. Expand the "SYSTEM" Key
d. Expand the "CurrentControlSet" Key
e. Expand the "Control" Key
f. Expand the "Class" Key
g. Look for a key containing the following string of letter and numbers:
{4D36E965-E325-11CE-BFC1-08002BE10318}
h. Highlight this key by left clicking once on it
i. On the right hand side you are looking for "UpperFilters" and "LowerFilters" under the "Name" column, once you find these delete them by right clicking on them and choosing "delete"
j. Exit the registry by clicking on the "X" in the top right hand corner of the screen
Reboot your computer
Posted on Jan 08, 2008
  • 3 more comments
  • Anonymous Jan 08, 2008
    Make sure you're selecting the correct key.
    There will be several keys that look like this one:
    and remember when you click it, only click it one time, just highlight it. Then on the right hand side you should see "upper filters" and "lower filters".
    To resolve this issue, change the transfer mode for your CD drive in IDE Channel Properties. To do this, follow these steps:
    1.
    Click Start, right-click My Computer, and then click Manage.
    2.
    Under Computer Management (Local), click Device Manager.
    3.
    In the right pane, expand IDE ATA/ATAPI controllers.
    4.
    Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel.
    5.
    On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 1. Then click OK. If
    the issue is not resolved after you change the transfer mode for the
    secondary IDE channel device 1, your CD drive may not be located there.
    Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved:
    Primary IDE channel,
    device 1
    Secondary IDE channel, device 0Note Primary IDE channel,
    device 1 is connected to your boot disk. This is the hard disk that typically contains your operating system.
    You don't need to worry about master/slave, you won't have those options with a laptop cd drive.
    Can you try the upper/lower filters fix again?
    I've fixed problems exactly like you're having several times by using this method. If that doesn't work, you probably have a malfunctioning drive.
  • Anonymous Jan 09, 2008
    Not likely that a virus would interfere with this.
    There will be not cables to check. You have a laptop, correct? The cd drive in a laptop doesn't connect with a cable. It just plugs directly into the motherboard.
    http://www.buy.com/retail/product.asp?sk...
    Scholar:
  • 152 Answers
If it appears on my pc.. then it is recognized and the problem is that either needs cleaning or clean the disk... here is a link on HOW
other wise.. if you are installing the CDrom.. then it must mean that the pin configuration isnt right and you have to set it to slave...or the gray cable isnt well connected
  • 1 more comment
    if you didnt install the cd rom, then i doubt the problem is about the hardware... if you did connect the cables to the cd rom, then you must check if the cables are connected correctly... the gray cable is THIS cable
    and this is a pict of the back side of a disk drive... the disk drive and the CDrom, at the back side are really similar... and to set a cdrom to slave, you have to move the white tiny block to certain position.. that position is shown in a diagram in the top side of the CdRom..
    but again.. if you bought that laptop and it worked, then i doubt its hardware. and when you install something on a WINxp system.. it is recognized instantly.. specially a cdrom...but still you have to configure the cdrom if it will be on slave or master... so thats why i tell you, you have to set it to slave..
    if you can see your cdrom on MY Computer.. then the CDROM its fine.. maybe it needs some cleaning, or maybe its to old or you are putting a dvd in the cd rom.. to know if its a dvd, the back side its usually purple...
    well.. you got it right.. when the computer recognizes your unit. it shows the icon on my pc.. like in the pict i am attachingso.. it must mean your cdrom is dead...
    and to find the gray (IDE) cable, youd need to open the laptop..but I am sure it will not be too dangerous for you to do it.. but if you dont want to take the risk, you could go to your local pc store and ask them if they have any.. but finding one wont be easy, i have never seen one being sold in my country (but again, laptops here are a novelty).. your other bet could be using ebay or amazon to find a deal and let them ship it to you and then you go to a local store and ask them to install it for you... i heard from a friend that they charge around 25 bucks to completely build a PC.. i am not sure how much can someone charge for a laptop...
    heres 1 bid for a cdrom for laptop
    and here is a list of dvd burners that are way better than a cd rom because you can also burn and read normal cds and DVDS...
    hope that helped
    also. forgot to tell.. most of the times, when the unit doesnt work.. the reading light begins to flash in a usual patern.. because when it works and gets a cd.. it lights up like 3 times and then like crazy... when it doesnt get the cd working.. it just keeps for less than a minute flashing, and each flash last around 1 second or half a second.
    that is the best way to know when your cdrom is almost dead..
  • 4,102 Answers
Hi are you sure its not installed and just needs the lense cleaning if not then try this.
1 select start
2 select controll panel
3 select add hardware
4 let the laptop scan for hardware connected
5 when finished look down list untill you see cd dvd you want to use
6 select this if you have the disk then when it asks if you have disk check the box for you have.
Then follow instructions then it should install the correct setting from the disc you have if dont have disk then dont check box and then it will search the web for compatable software.
Let me know how you get on and if you need further help
  • paul proctor Jan 11, 2008
    Hi i know this sound stupid but have you tried using a lense cleaner to make sure the problem isnt dust on the laser lense
6ya staff
SOURCE:
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
I have a CD ROM that is no longer being recognized by my Vista laptop.
Hi, if after a few computer restarts, it still fails to recognize, save your important docs etc, and do a system recovery back before the time you noticed the error.
If after 2/3 attempts still no sign, you are looking at a complete system install!
But first try accessing "Device Manager" clich DVD/CD/Rom Icon. Click Remove.
Restart computer, hopefully this should force a new item found and installing prog sign should appear during startup?
May 26, 2011 | Computers & Internet
My DVD/CD Drive is not recognized by my laptop. It doesn't appear at device manager at all.
it has failed of your ram is failing and causing errors on your fsb
Dec 02, 2010 | Computers & Internet
My computer no longer recognizes my cd/dvd drive
try to remove it and start laptop and turn it off put it back in and restart it and it will install a default driver for it, hope this helps
Feb 12, 2010 | Acer Aspire 4520-5582 Notebook
I did PC restore using Dell F11 reset tool / no dvd or cd recogni
Go to Dell's support site and to their driver page. Put your model number in the box for a search and a page with your drivers will appear, download the drivers for your model and do a re-install of them. download them to a temp folder and when they are downloaded, double click and they will self install, put off rebooting until you install them all.
Sep 04, 2009 | Dell Dimension 8400 PC Desktop
CD/DVD Drive missing. No UPPER or LOWER FILTERS
Shut down the laptop completely and then Remove the CD/DVD Drive from your laptop and restart it. Then See whether it notices it absence or not. Shut It down completely and then put the CD/DVD Drive back in and then Restar it and check again whether its appearing or not. if not then-----------> Go to BIOS and make sure that bios is detecting the CD/DVD Drive and its ON. It would Surely solve the problem. Install any New Firmware From For The CD/DVD Drive available on the HP website.
May 01, 2009 | Microsoft Windows XP Home Edition
Cd drive not recognizing cd's
nope it happens to me, if your laptop still under warrantee call toshiba and they will replace it to you. the problem is the lens not reading the cd, try to clean it by dvd cleaner if its not working replace it.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 19, 2009 | Toshiba Satellite M115-S3094 Notebook
My CD/DVD drive does not work
have you changed the cd and install a music cd if it still does that same thing chances are you need a new cd drive
Mar 12, 2009 | Compaq Presario R3000 Notebook
IBM R32 ultrabay is not recognized
Did you leave the battery in the R32 for long enough for it to charge up? (Like overnight?) Another thought is that if you bought the battery used, it may not be any good.
Ron-
Feb 23, 2008 | IBM ThinkPad R32 2658 Notebook
Toshiba Satellite A105 Notebook Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
