Question about Toshiba Satellite A105 Notebook
Help me please with a cd driver not working?
How can i fixit?
  • 1 more comment
  • gio4unow Jan 08, 2008
    please help.....!!!
  • gio4unow Jan 09, 2008
    its i hink the cd driver...whn i placed a cd it doesnt open....after I wait I go to my computer and try to open it and it says error I/O device error...
    its brand new
    Problem Solver:
  • 7 Answers
Lol, get a NEW/COMPATABLE one.
ps. be more specific (is it the cd drive driver or a driver cd)
Posted on Jan 09, 2008
  • ganjabymilk Jan 09, 2008
    both realy is get a update/hotfix :S lol
LITEON DVD/cd rewritable device not reconized
Since the system originally had another version of Windows did you run the Upgrade Advisor and
check the Compatibility Center for the CD/DVD compatibilty (and other devices as needed).
Windows 7 Upgrade Advisor - please run this now.
http://www.microsoft.com/windows/windows-7/get/upgrade-advisor.aspx
Also check the Compatibility Center (for major devices)
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Check with the System maker and the Device maker for information about drivers for Windows 7.
(BIOS, low level chipset drivers, and other major device drivers).
Check these :
The DVD drive does not function after you install Windows 7 - these are different Sony drives
however the same issue could be affecting your drive.
http://support.microsoft.com/kb/975270/
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs
http://support.microsoft.com/kb/982116
If the System can run Windows 7 AND there are drivers for the devices these might help :
References to Vista also apply to Windows 7.
Stage 1 : Please do all the below even if you have done some before as it is often the total
process which solves the issue.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab -
click Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL -
REBOOT this will refresh the default driver stack. Even if drive is not shown continue
below.
Then work your way through these - remember the drive could be bad, could have a loose
cable or slight corrosion on the contacts (usually for a laptop) and other issues.
http://support.microsoft.com/kb/314060 - a Mr Fixit
Manually try this fix if the 314060 Fixit did not work
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Your CD drive or DVD drive is missing or is not recognized by Windows or other programs -
a Mr Fixit
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to
Windows Vista
http://support.microsoft.com/kb/929461
When you insert a CD or a DVD, Windows Vista may not recognize the disc
http://support.microsoft.com/kb/939052
Your CD or DVD drive cannot read or write media - A Mr Fixit
http://support.microsoft.com/gp/cd_dvd_drive_problems
CD/DVD drive does not appear in Windows Vista, or you receive this error during Windows Vista
setup after booting from the DVD (AHCI)
http://support.microsoft.com/kb/952951
CD-R drive or CD-RW drive is not recognized as a recordable device
http://support.microsoft.com/kb/316529/
Hardware devices not detected or not working - A Mr Fixit
http://support.microsoft.com/gp/hardware_device_problems
Another possibility is that the cables are loose. Remove ALL power, then check cables in both
ends. Remove and replace, do not just snug. For laptops you can often clean the power and
data contacts with a pencil eraser.
Some DVD drives do not use the Windows default drivers so check with the System maker and
device maker to see if there is firmware or drivers for you drive if needed.
Stage 2 : You could have drive issues as the CD/DVD is actually 4 drives in 1 case ( CD & DVD
burn and CD and DVD read). So it is not unusual for 1 or 2 parts to not function while the others
do so properly.
Did you complete the troubleshooter for the drive that still does not work? There are some
registry entries that the troubleshooter does not fix and those "might" be the cause.
Check with your System Maker and Device maker for both possible firmware updates and the
correct Registry entries for your drive.
These are the keys I think are the ones in question - for the CD/DVD drive sub-keys of course
as there will other sub-keys in these keys. Be sure to ask for specific keys involved as well as
the settings.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\IDE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Hardware Profiles\0001\System\CurrentControlSet\Enum\IDE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
You probably can find more info here and maybe even the exact registry settings for your CD/DVD
drive from someone with the same model.
Forums - a lot of real expert help
http://club.myce.com/
CD/DVD units
http://www.myce.com/storage/
Use DevManView to locate CD/DVD in registry (be careful and make a Restore Point before
changing anything) - find the device in DevManView and then Right Click on it Open in RegEdit.
DevManView - Free - an alternative to the standard Device Manager of Windows, which displays all
devices and their properties in flat table, instead of tree viewer
http://www.nirsoft.net/utils/device_manager_view.html
Hope this helps.
Oct 20, 2013 | Philips Dh-16a3s & Lite-on Dvd/cd...
Tsstcorp cddvdw ts l633p error code 19
Code 19 means there is a driver conflict such as two devices trying to use the same resources.
Try this - Control Panel - Device Manager - CD/DVD - double click the device - Driver's Tab - click
Update Drivers (this will likely do nothing) - then RIGHT CLICK the drive - UNINSTALL - REBOOT
Normally the above will fix that issue if not work your way down through these even if you have done
them before.
The CD drive or the DVD drive does not work as expected on a computer that you upgraded to Windows Vista
CD/DVD drive does not appear in Windows Vista, or you receive this error during Windows Vista setup after booting from the DVD (AHCI)
Hope these help.
Jun 14, 2012 | Computers & Internet
CD/DVD driver not working
A few solutions:
1. Have you tried to clean your cd/dvd lens? Probably your lens is getting weak.
2. For advance user: Locate, and then click the following registry subkey:
- Look for DVD/CD-ROM drives and delete the subkey.
- Restart your machine.
3. Let Microsoft FixIt help you:
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
Worst case - Get a new CD/DVD-ROM for the replacement.
Don't forget to thumb up! ;) Good luck!
Feb 25, 2012 | Lenovo 3000 Y410 Laptop
Optical drive not recognized by windows
Hi,,,,,,,,,,,,
Do these to clear corruption and repair/replace damaged/missing system files.
Start - type in Search box - COMMAND find at top of list - RIGHT CLICK - RUN AS ADMIN
sfc /scannow
How to Repair Windows 7 System Files with System File Checker
http://www.sevenforums.com/tutorials/1538-sfc-scannow-command-system-file-checker.html
Then run checkdisk (chkdsk).
How to Run Disk Check in Windows 7
http://www.sevenforums.com/tutorials/433-disk-check.html
After the above :
below.
a Mr Fixit
Windows Vista
do so properly.
the settings.
CD/DVD drive from someone with the same model.
CD/DVD units
all devices and their properties in flat table, instead of tree viewer
Hope this helps......
GOOD LUCK.................
Sep 24, 2011 | HP Pavilion dv6647cl PC Notebook
It doesnt recognize a dvd rom is connected to cp it says cd rom driver not found
Reseat the drive if it is removable.
See if you can boot to the drive using a bootable CD (Windows CD etc) If you can boot to it, then it is a software issue.
run the fixit utility here: http://support.microsoft.com/kb/982116 if that doesn't resolve, then use the manual steps listed below the fixit tool. If that still doesn't resolve, the drive is likely bad.
Sep 24, 2010 | Computers & Internet
We had to get a new pc. It is windows 7. the ads dvdxpress dx2 software cd will not work. there website dose not work so no supprt. help! Charlotte
HI there,
Often, the automated Microsoft Fixit Tool Utility on the page belwo will solve cd/dvd problems. If not, it will sometimes tell you the exact problem which can be solved another suggested way.
A favor, if this does not work and you find this post only "Moderstely Helpful", please don't leave 2 thumbs up. It just lowers my rating so I get "punished" for trying to help someone for free.
Regards,
Marcus
Sep 21, 2010 | A D S ADS Technologies USBAV-701-EF DVD...
Norton 360 install has replaced/overridden DVD drive
Hi, I can certainly understand how you feel and hope I can help.
error 19 isnt necesarily a corrupt driver, it can be 2 drivers trying to use the same resource (as in norton's backup drive and your cd drive, for example)
Try this - Click the start button, right click on "Computer", select "Properties", then click "Device Manager" in the upper left hand corner.
Open the bit that says "CD/DVD Drives" and try right clicking on the drives there and selecting "Update Driver Software". This will probably do nothing. Don't worry, I didnt really expect it to. Now right click on the drives, and select "Delete" and then reboot. This will reset the drivers for ya.
This fix usually DOES work. Most of the time. If it doesnt work, try the ones below.
Hope these help.
Dec 05, 2009 | Gateway GT5435E Refurbished AMD Desktop...
I purchased a Dell Computer back in 2004 which came with Sonic Digital Media Plus v7. My PC has Windows XP Operating System. A few days ago I decided to install Version 6.0 of Roxios Easy CD/DVD Burning...
Try uninstalling Roxio and the Sonic drives and run Fixit. Then reboot and install Roxio first then the Sonic driver.
If this doesn't work uninstall again as previously, install Roxio and check the CD/DVD if necessary run Fixit then install Sonic driver.
Aug 01, 2009 | Computers & Internet
My Mad Dog Dominator 5-in-1 External CD-RW+DVD-Rom doesn't work.
Here is a link from Microsoft for unrecognized external devices. Click on the "Fixit" button to install the registry patch. Hopefully this will get you going. Best of luck.
Greg
http://support.microsoft.com/kb/925196
Jul 04, 2009 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
15 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
