Question about Sharp R-1491 Microwave Oven
I'm trying to remove a Sharp R-1491 microwave. I
I'm trying to remove a Sharp R-1491 microwave. I have removed the 2 screws that go through the cabinet above the unit, but cannot get the unit to come out. I cannot see anything else holding the unit in place.
SOURCE: Microwave installation
Hi there - just figured out how to get mine out. Here is what I did. There are two screws at the top under the faceplate. There is brace on each side with 2 screws on the bottom and one facing out. Remove the two that face out. Next look under the unit and there is a brass looking cover with 2 more screws. Mine had writing on it about servicing professionally. Remove that two screws, the two power connections and the unit should slip right out.
Posted on Oct 08, 2007
  • 619 Answers
SOURCE: Microwave installation under cabinet, no rear wall
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Posted on Jan 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Removing over the range microwave
You can download the installation instructions, which are quite helpful when uninstalling.
We have uploaded them to our site for you here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Removing a built in Jenn-Air Microwave from it cabinet...
First of all, what are the symptoms? Please reply back and I'll be happy to share my thoughts.
Many parts can be accessed without removing the oven from the wall by just removing the control panel.
You need to be sure the cord is unplugged, then you remove the vent grille that runs across the top.
Then you'll see a screw holding the control panel in place. Once that screw is out, you can lift out and out carefully to separate the control panel form the chassis.
If you pull any wires off the control panel, mark and/or photograph them first to be sure you get them ALL back in the right place.
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Before you start, we have *critical* safety & disassembly info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
While they don't have their installation instructions online, the owner's manual is online here.
Posted on Mar 31, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: removal from a motorhome
We regularly repair the circuit boards of microwave which are hit by storm surges, etc.
This repair usually runs $39.95 to $64.95, depending on if we have to replace the low power transformer. I just thought I'd mention this if you're interested.
But if you've decided on replacing it, the installation manual should be helpful in removing it from the wall. See it here.
You will need the free Acrobat Reader to view or print it.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 06, 2008
Can not remove from wall
Here's a link to the instructions for mounting the unit on the wall. Take a look at the section that shows 2 arms protruding out into the microwave where the microwave is secured by a bolt. Have you removed these bolts? If so, the microwave should pull out. Here's the link to the guide:
http://www.microwavedisplay.com/r1490_r1600_r1750_r1870_r1871_r1872_r1874_hood_inst.pdf
Mar 07, 2010 | Sharp R-1491 Microwave Oven
The door to my Microwave (Sharp R-1491) will not close. The inside latches are not working. Is there a way to fix this? Or is there a microwave that you would recommend (as inexpensive as possible) that...
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
But the best place to order Sharp parts is
Encompass or you can call them at
If you need to remove it form the wall, here are two sets of installation instructions that may be close enough. here and here
If the unit needs to be replaced, you can ask Sharp if they have a "drop in" replacement. You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Jan 14, 2010 | Sharp R-1491 Microwave Oven
Need wiring diagram for sharp carousel microwave model r-1491
I found one for mind on the inside of the outside cover caseing. just need to unmount from wall and remove the six screws of the back to remove it.
Nov 13, 2009 | Sharp R-1491 Microwave Oven
Our r-1491 microwave fan won't shut off, even when
its just the door switches playing up on you,,but is it worth getting it fixed? after all a new microwave onle costs from £50 up today,,
please dont try fixing it yourself unless you realy know what you are doing in there, there is 1000's of volts hiding in there even if its been switched off for days, and them volts will kill you,
have you ever seen a stun gun working???it realy hurts you,,,,,this microwave has the stun guns big brother inside of it,,and it wont stun you,,it will kill you,, is it realy worth that for a fuw bucks?
Oct 24, 2009 | Sharp R-1491 Microwave Oven
How do i remove sharp microwave from wall model
The only problem that ricksterboy doesn't list, is there are also two screws located underneath as well. You have to take off the filter screens to find them. They secure into steel supports inside the microwave.
No getting the micro off the wall w/o removing them, or using a sledge hammer...which after all the time we used trying to get the thing off the wall, seemed like a good theraputic option.
Lucky we took off the vent cover and discovered the additional anchors.
Aug 22, 2009 | Sharp Microwave Ovens
Where is the fuse located on the sharp r-1491. microwave shut off once started and wont power on. thanks
when you open the cover you can see the fuse in a small pcb on the upper right side of the over.
Jun 11, 2009 | Sharp R-1491 Microwave Oven
Sharp r-1491
Yes call shart help line, you can find it on 411.com or googles, with you model and them the part # for the bracket and ask them were you can purchase it.
You can also try sears with your model, there or a very excelent sourse for question's on parts, if they have this model they will have all info.
Regards
Bob the builder
Feb 07, 2008 | Sharp R-1491 Microwave Oven
Sharp R-1491 Microwave Oven Logo
431 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
