Question about Motorola Mobility L9 Unlocked GSM Cell Phone
I Try To Put The Usb In But It Doesnt Work - Motorola Mobility L9 Unlocked GSM Cell Phone
USB port not working
Sometimes i know you have to plug in a usb from the monitor to the computer. If this is already done simply unplug that usb device and plug it into another usb slot on the computer itself. If this does not work try replacing the cable. If that does not work try testing by plugging in something on the computer to make sure the usb ports work and then try in monitor, if it doesnt work in the monitor then something went bad with the monitor. Check for warranty. Same with computer if it doesnt work.
- please vote for me :D
Mar 09, 2011 | AOC 19" LCD HDTV Monitor
I just got this wireless mouse, i put batteries in it and plugged in the usb it still doesnt work, why?
You may need to 'connect' them.
On many wireless mice, there is a little button that says 'connect', on the mouse (and possibly the USB).
If there is, try pressing both of them within a few seconds, and they'll connect with each other - and then it should work.
Good luck
Jan 12, 2011 | GE Wireless Optical Mouse
I can not open my usb flash drive. computer unable to detect flash drive. what do I do?
try another usb port 1st,preferably on the back side of the pc.If it still doesnt work try it on another pc.if it doesnt work on aother pc its more than likely bad.
Aug 20, 2010 | Computers & Internet
I put the usb into any my laptops usb ports and it just doesnt disable my touchpad or even want to work when a couple of days ago it did.
it shouldnt disable your touchpad unless theres an option for it too but if its not working try reinstalling the driver in control panel
Apr 08, 2010 | Logitech Cordless Mouse
Trouble accessing files on usb
It is probably a driver error on your operating system. I suggest trying a couple different ports- if that doesnt work try a different computer. If that doesnt work most likely your drive file system is damaged and needs to be formatted. Good luck!
Sep 23, 2009 | Dane-Elec DaneElec 4GB USB Drive Red Hard...
My computer doesnt recognize my sansa express and it used to
check usb cable and make sure that the cable is connected properly .
Try connect to other usb port .
Hope it helps
Jul 17, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
It doesnt work...
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Apr 09, 2008 | Razer DeathAdder RZ01-00150100-R2M1
Motorla v3
Go to this site for latest drivers, if your cd is not responding, but try usb cable in a different port http://direct.motorola.com/ENA/SoftwareUpdateSummary.asp?country=AUS&language=ENA&web_page_name=SUPPORT&strCarrierId=&strPhone=V3x&strCable=Mini%20USB%20Data%20Cable
Mar 08, 2007 | Motorola Mobility OEM Bluetooth USB PC...
Motorola Mobility L9 Unlocked GSM Cell Phone Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
