Question about Nokia 8810 Cellular Phone
I'm confused about the Nokia 8810 battery. It reads "Nokia BL-5X" 3.7 v, but new replacement batteries are just listed as 600 mAH, 3.6V. What will work?
Free unlock code nokia bl 4c 860 mah
Hi what is your nokia mobile exact model? If you need unlock you mobile you can visit this site Theunlockarena.com here you can get the code and unlock your mobile easily. To get the code you have to mentioned your mobile model,which country is locked now,network provider and imei number. Then they send unlock code through email.
Theunlockarena.com
Jul 26, 2014 | Nokia BL-4C - Cellular phone battery...
My nokia phone is askin for a security code and i avent eva had one what is it pls help
There is No BL 4 model Phone in Nokia That is Nokia Battery type so please specify the Model Correctly..if you forgot the security code or Don't know the code means try default code 0000 or 12345 or 1234 if not works means You can get the Nokia Master Reset code from here
Onlinegsmunlock.com
and reset from security lock,Nokia DCT master reset code available there.
Oct 05, 2011 | Nokia BL-4C - Cellular phone battery...
Philips SE 455 twin set cordless: The charge lasts less than an hour when using speaker phone, so I am looking for replacement batteries. Phones only 2-3 years old and absolutely fine in all other...
A higher capacity battery should work even better because a fully charged 900 mAh battery allows the phone to operate 50% longer than a 600 mAh battery between charges. I have had good results with Rayovac Recharge Plus 900 mAh in my Philips SE450. This phone will latch and not operate upon ringing if it doesn't like its batteries (probably high internal resistance), even though the batteries test good on a battery tester.
Jun 28, 2011 | Philips 2252 Twin Cordless Phone
Cannot find the power button on my Nokia BL-4c.
hello , there is no such power button anywhere on the battery
Apr 18, 2011 | Nokia BL-4C - Cellular phone battery...
I had got bl-4c 860mah battery of nokia and its big problem is its battery back up is so poor..how can i improve its power backup
li-lon batterys like other batterys burn out over time they stop holding as much power as capable the fix is easy buy a new battery and it will restore you to full power
merry christmas
Dec 22, 2010 | Nokia BL-4C - Cellular phone battery...
I NEED Thomson battery Model No:KLB55N80
Here is a link to a site that sells batteries, I used it for my Panasonic cordless. Your GE 25839GE3 model number phone is listed. http://www.emtcompany.com/ge-2-5839ge3-battery-3-6v-600-mah/pcf03.html
Dec 15, 2010 | GE 25839GE3 Cordless Phone
What is the IMEI for an nokia bl-4c
IMEI numbers are not for batteries they are UNDER the batteries written on the cellphone and they are used to track cellphone not BATTRIES
Nov 16, 2010 | Nokia BL-4C - Cellular phone battery...
How do you fix water damage in a nokia bl 4c phone
Do NOT turn it on. remove battery, bury in Tupperware bowl of rice and seal . leave 3 weeks as rice will absorb all the moisture in the phone.
If you HAVE tried to turn it on, you are most likely SOL now.
Nov 08, 2009 | Nokia BL-4C - Cellular phone battery...
I need a battery
http://www.needbattery.com/searchView/3-6v-600-mAh-Cordless-Phone-Battery.html?type=cf&equiv=Bell%20Equipment%20GP60AAAH3BML&productCode=BCO1051&internal=0&refx=G00GX&gclid=CMCX5cO1xJkCFeRM5QodbQMqKg
You can check the list for the model# of you phone, its easier to search with the model# of phone then bat #
Mar 28, 2009 | BellSouth GH5831BK Cordless Telephone
Nokia 8810 Cellular Phone Logo
153 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
