Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
I have been using my Maxtor external drive for about 3 months without any problems, but in the last week it has stopped working and I get the error message no external drive found or either either the partition on the external drive is not recognized or the external drive has no partition
    Master:
  • 956 Answers
Sorry, Maxtor prog on poota is currupted. Have you recently downloaded programmes? When updating, some progs have a nasty side-effct of hitting some other programmes, not all the time,just your important ones?
You will have to uninstall and reinstall Maxtor prog, Not sure there might be a repair facility, not sure but it worth a try before uninstalling all.
Posted on Nov 14, 2009
Just stop working.. one year old
It should still be in warranty, even if it is slightly past the 12 month period a phone call to the supplier might bring a pleasant surprise. It really should have lasted longer
May 27, 2015 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Hello, I have a Maxtor 500gb external hard drive since 3 years now. Since last week he computer recognises it but after few minutes it it shuts down with the error message coming up as 'Not...
Hello, please try the following:
1. Try changing your drives usb cable 2. Run a disk check on your drive to fix any errors. If the problem remains then its a sure sign your drive is about to fail, backup or recover your data quickly using drive recovery software.
All the best, thanks for using FixYa.
Jul 23, 2011 | Computers & Internet
External HDD is not working
You probably have conficker worm because it stops your pc from reading usb's or any external HDD. Or the worm might of infected your HDD since it spreads through usb and internet. Seriously you should get your PC scanned just incase. P.S. Its just a possibility.
Jun 09, 2009 | Maxtor Hard Drive
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Fried my maxtor 3200 external hd
The drive will have to be slaved to another drive in another machine.
Apr 09, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Can't detect an external Hard drive (Maxtor 1TB)
im going to assume your on XP for these instructions. other wise you still need to do the same thing.
right click the my computer desktop or the start menu. go down to properties. open the hardware tab. open the device manager. Scroll down to it, remove the driver, just delete the whole entry. unplug the hard drive, then plug it in again. See if that works.
hope this will fixya....
Jan 05, 2009 | Maxtor Hard Drive
Maxtor one touch 3 external hard drive 300 gb
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Sep 10, 2008 | Maxtor OneTouch III Mini Edition (R01E100)...
Hello
Kind Regards
Andrea
Aug 11, 2008 | Maxtor 300GB ONE TOUCH 2 USB2- 7200RPM...
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
195 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
