Question about Troy Bilt 5.5hp Self Propelled Mower
Carb and airfilter assembly got disconected from the rest of the lawnmower.I see wher two hoses are connected however I wonder if there should be some bolts .its a troybilt 6.5 self propelled lawnmower
landsend
  • 1066 Answers
SOURCE: Troy Bilt Self Propelled Lawnmower drive belt
belts usually come off for a few reasons.
They become loose...stretch or the tensioner moves,  Make sure that none of the tightening bolds are slipping.  You can dab them with a bit of paint.
when the pulleys are not in alignment or crooked or bent.  Eyeball the path from one pulley to another, also make sure the tensioner is in alignment and there are no other obstructions.
good, high quality belts are required, and they must be real drive belts...not regular v belts.  If there is a way to watch the belt in operation you can usually see what's going wrong.
On my lawnmower I had to grind some metal away where the belt went from the motor to the transmission.  Good luck
Posted on Apr 18, 2009
#1 Taper
  • 1040 Answers
SOURCE: Need help with belt on Troybilt self propelled push mower
Try removing the pulley in order to put the belt back on.
Jim
Posted on May 30, 2009
  • 154 Answers
SOURCE: How do I remove the self-propelled drive belt?
remove one wheel to expose the belt ,
Posted on Aug 05, 2009
SOURCE: Troybilt self-propelled mower - model 556 won't start
pipe from carb to engine broken. couldn't tell until covers & fuel tank removed. also part of deck holding engine came apart on mine. due to excessive vibration???
Posted on Mar 16, 2010
vincob
  • 718 Answers
SOURCE: variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Posted on Jul 26, 2010
Have a 88 polaris trail boss. dosnt have any hoses hooked up to carb. cant find anything telling me how hoses are supposed to be ran. any help
There is usually only one hose connected to the carb... it goes from the fuel tank-=fuel filter to the carb at the top. The hose is s similar diameter used in lawnmowers and sold by the foot. There is a cable from the throttle which is tricky to get on sometimes as there is a spring on it. If you've never owned a motorcycle of removed throttle cables before, get with someone who has. The needle valve is visible protruding from the bottom of the throttle cable. There is a keeper clip on it and it sets on a particular groove on the needle valve.
Feb 28, 2015 | ATVs
I took my toro 6.5 lawnmower carb apart and cleaned, now fuel spurts out of red tube into the air cleaner. Why is this happening?
Sounds like you assembled something wrong when reinstalling the carb. Or your missing a step or two.
Mar 18, 2012 | Toro Power Lawn Mower
Lawnmower starts and dies... where is the main jet for the carb?
try cleaning the air filter, then a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season.
Aug 27, 2010 | Poulan "Poulan" Push Mower
Snapper lawnmower will not start - sparkplug is good, air filter clean, no idea what is wrong
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the vertical intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jul 05, 2010 | Omega Rear Drive Wheel Snapper Mowers
I can't start my honda lawnmower, checked the oil, put new gas use choke,it gives litle sound but not enough to start
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jun 10, 2010 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
There isnt any gas getting to the spark plug but the carb is clean and the gas is getting to that
There is one hose connected to carb from the tank.Use a compressor to blow the dirt that resting inside that hose assembly.
May 20, 2010 | Motorcycles
My victa statesman lawnmower turns over then dies
first thing to do is take gas tank off and clean it good, remove gas line & blow out. you must remove carb. & give it a good cleaning, blow out all passages, you may need a new carb. kit.
Dec 14, 2009 | Garden
Why is my 4.0 crafrtsman lawnmower flooding gas into my airfilter
float is sticking in the carb. Pull carb clean holes with paper clip put back together.
Jul 19, 2009 | Craftsman Garden
Engine sputters and revs up and down as you push or pull it.
Hi Jim,
Does your carb have a priming bulb? If it doue, it sounds like you have a tear in the diaphragm on the carb. Check for small tear, holes or rips in it. Hope this helps.
Jul 07, 2009 | Garden
Lawnmower starts but won't run-replaced airfilter and plug cleaned carb
If it is starting and not continuing to run it still sounds as though something is blocking the fuel flow. If the carb has been cleaned out, literally torn down and the needles cleaned so that no small debris is clogging them, check the fuel tank and lines for anything that could be restricting the flow to the engine. Remember that it's recommended that you replace the fuel line (cheap fix) when you dismantle the carb. Removing the line breaks off small pieces of the rubber in a worn line, which can re-block a freshly cleaned carb.
May 12, 2009 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
71 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
