I have Audivox DVD Player can help with Region Free Code
The DVD player Audivox Model is D 1718PK
Do you know the region free codes.
Thanks
Mike
  • 1 more comment
  • ukten Jan 19, 2008
    Just quick note for the DooDad
    Your the Best...
    Mike
  • valhalo Feb 22, 2009
    I have a toshiba sd-280ekb purchased U.K. Feb 2008
    I need to set Multi Region. Any ideas?
  • joic Apr 16, 2009
    Yeah I have a Toshiba SD280EKB and don't see how to unlock for multi region or change regions as required. Not sure the Hack for the Audivox will help??
    Anyone have something for the SD280EKB??
    Scholar:
  • 64 Answers
Originally this "hack" was for the 1708 model but it works for the 1718 model too.
1) Open the DVD Door, on remote press Setup, Right, Right, Right (that’s the arrows in the middle of remote)
2) Enter 9653,a service page will appear,
3) Use Up/Down Bottom to change region Codes
4) Set to 0 (zero) for multi-region
Posted on Jan 08, 2008
6ya staff
SOURCE:
What is the multi-region code for Toshiba DVD Player SD5300KC
These WEB sites may have a region free code for your player.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Jan 03, 2013 | Toshiba SD-3900 DVD Player
Cant play a region 1 dvd
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Jul 12, 2011 | Audio Players & Recorders
I am in Australia and have just bought a DMR BW500. I have a dvd from Japan which won't work on it and I have been told that if I unlock the region code, then it will work. So how do I unlock the region...
The following works on a region 4 player. With no disc in the player and the drawer closed, press stop, stop, setup, then 3,8,8,8,3 and the desired region code, (0 for multiregion). Nothing will appear on screen. Then switch the player off and back on. It should now play discs for any region
Sep 04, 2009 | Televison & Video
How to solve disc region error?
Here's how to make it region free..
1.Keep Tray in eject position
2.Press Setup from remot
3.Go to preference page
4.Press"138931"
5.Using Navigation Key change region code to "0"
6.Press "OK"
7.Regionfree!!
Jay
May 25, 2009 | Televison & Video
Wrong region code
Check this thread:
http://uk.answers.yahoo.com/question/index?qid=20080820055911AAxPqVw
If you want to permanently change your firmware and you are comfortable working with this, then check this thread:
http://club.cdfreaks.com/f87/where-latest-version-1-21-pioneer-dvr-112d-firmware-thats-region-free-224385/
Feb 07, 2009 | Computers & Internet
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Region code
I have a region Code For A Philips HTS-3544 which is 1 model Down. You can try it, it may work or it May Not.
Heres How:- power on the TV/DVD without any disk in the player.Press open/close eject.
Press Stop 7.3.4.4.6.6 ( on the Remote )
The menu code appears On The Screen.
Press 0 for region Free, or the region Code Required.
Power Off and then on Again, if the codes have worked, your dvd player is now region free.
If this works please rate as Fixya.
many thanks mike @ Compurepair.
Aug 28, 2008 | Philips HTS-3555 System
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Region free codes
I bought a panasonic portable dvd player for the kids for christmas, unfortunately it displays wont play in the region. I do not have a code for it nor a remote control. The model is LS850. Can you help.?
Jan 04, 2008 | Televison & Video
Region Free Code: Philips DVP 5980
this worked perfectly, thank you!
Dec 19, 2007 | Televison & Video
Televison & Video Logo
191 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
