Question about Philips HTS-6500/37 System
When loading a disc it will show loading and then it will show no disc and I have run a cleaning disc but did not help
  • 6,784 Answers
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Posted on Nov 14, 2009
  • 1,056 Answers
The laser assembly is bad. There is no easy fix to that. The only solution is buying the whole laser assembly, which is had to get. If you can order them it may take up to two weeks to arrive. Replacing the laser assembly is also not easy.
When i put one dvd or Cd in the display Show Loading then ERRO disc whats happening?
if the discs did play before this happened you might need to have the laser inside cleaned,
get a laser disc cleaner and run that through it.
Dec 13, 2016 | Televison & Video
Blaupunkt 5 disc cd player is showing 'no discs' when discs are inserted
The indiatation of No dics shows that the cd data is not being read by the optical unit.this could be weak or failure of the laser of the optical unit. what you can do is only to clean the lens and test. if not you will have to replace the optical unit. Further a failrue of the processing electronics is also possible.
Hence check after cleaning and load a good clean Cd to test. Hope this helps? Good day
Jun 24, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
We can not get our PSP to run games anymore. We
Your disc may be dirty scratched or damaged. Also your laser might be broken or dirty. Try cleaning the disc and cleaning the las.er
Mar 12, 2010 | Sony PlayStation Portable (PSP) Console
PSP Not Loading Games
You most likely need to clean the lens. Local game stores have kits that clean it for you.
May 28, 2009 | Sony PlayStation Portable (PSP) Console
"no disc" message when disc is inserted
Id the disc clean of debris dust and scratches? Cleaned the unit aswell with a blue ray cleaning kit? Please do these things, if you find this helpful please use Fixya when rating Thanks
Apr 26, 2009 | Sony BDP-S300 Blu-Ray Disc Player
JVC - XV-F80 DVD Player
Either the disc or the player likely need a good cleaning. Clean the disc with a soft cloth, clean the player with a good cleaner disc.
Feb 26, 2009 | JVC XV-F80 Multi-disc DVD Player
DVD not running
check the cables or replace it. Also cleaned the player with 2 heads lens cleaning dvd. try with good lens cleaner dvd.
click this link for more info
Feb 01, 2009 | Philips MCD702 Shelf System
Xv-dv333 won't load dvds
Try running a cleaning disc. After that it worked for me.
I have a XV-DV323
//Kongolasse
Nov 29, 2008 | Pioneer XVDV830/SDV830 DVD AUDIO HTP...
DVD won't load
Try manually cleaning the pick-up.
Cleaning disc's and tapes DO NOT WORK
May 26, 2008 | Audiovox MMDV2
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Philips HTS-6500/37 System Logo
1,829 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
