Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The oven of my GE Spectra XL 44 will not light on
The oven of my GE Spectra XL 44 will not lit on any temperature settings other than broil. The cleaning feature does not come on. I was able to turn it off and unlock the door after I had waited one hour for the cleaning to start. What is wrong?
Jackie
  • 22 Answers
Digital or analog controller
Posted on Nov 14, 2009
Testimonial: "digital"
GE XL 44 oven will not come up to temperature. Oven lights but will not heat beyond 250 degrees.
The most probable reason the oven isnt heating very well is because of a weak igniter,since that igniter is weak its having a hard time fully opening the gas valve so the flame is very small and thusly not producing much heat,by replacing the igniter the gas will flow properly and heat to a high tempature.
GENE
Oct 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My gas oven will not heat up above 300 degrees and
You may have 2 problems.
One. The temperature sensor could be bad. You can remove the temperature sensor and check it with a ohm meter. It should read 1050 to 1150 ohms. If not. It is bad.
Two. The glowbar ignitor could be bad and not igniting the gas safety valve.Open the bottom drawer of the oven and set the oven to bake. The burner should light in 60 seconds or less. Re-light should be about 30 seconds or less.
If it takes longer the ignitor is bad.
Dec 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
F3 code on ge xl 44 gas range
F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact
Jun 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL 44 wont keep temperature
Replace the oven temperature sensor part # wb20k0004
Mar 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL 44 gas kitchen range. Oven does not work
Sounds like the switch module is defective.  You might get lucky if you power down the stove for half an hour and then reapply power.   Sometimes they reset.  If you, enjoy.  If not, you will need that module.
Nov 09, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
294 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
