Question about LG MU-42PM11 47 in. EDTV-Ready Plasma Television
Fuse fs1 blown
Replaced fuse and blows again (T2.0AH 250v). Picture is just very faint images
  • rcboak Jan 09, 2008
    LG MU-42PM11
3 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: Model 37M32ID/37 magnavox LCD.
I think that is the wrong fuse but still it would pop if you have a line problem on the circuit that fuse is piping for a reason not the value but there are more issues on the circuit then what you repaired I would start digging and see if there are more popped caps! not in the power supply but else where like the hd push board or the decoder in better terms.
Thanks hope this helps if you cannot get it done take it in for a estimate as estimate will tell you the issue fixed or not and you can take that advice from that tech and repair your TV!!
Please do click the accept button if you like my advise.
May i suggest a service manual?
Posted on Dec 19, 2009
Testimonial: "rulds2008 provided good and timely information and advice. I appreciate the quick turn around."
SOURCE: lg 42 plasma model 42pc3d-ud: had a really bad picture so
I Have An LG - 42PC3D-UD, When I Turn It On "It Have Sound And A Very Bad Picture.
Posted on Apr 13, 2011
Damage 110v / 220v
fuses only protect against excess current flow and are not affected by voltage
take it in for a proper diagnosis and quote
Jan 09, 2018 | Yamaha HS50M Active Studio Monitor (Pair)
My speakers keep shorting out would the power cord be a reason?
No, the power cord is not the issue. Tell us more about the symptoms
Oct 14, 2012 | M-Audio Studiophile AV 30 Computer...
Fuse blown on incoming power replaced fuse but no luck
replaced the t8ah 250v fuse and it still blow when i turned on the tv
Oct 19, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
Electrolux oxygen 3 fuse
The fuse on my ELECTROLUX Oxygen3's sumo board did have clear markings: F5AL250V - this is a 5A/250V 20mm fuse made by BEL FUSE, however, any other such fuse should work. The fuse on my board was blown (luckily, what caused it seems to be a glitch as replacing the fuse was all that I had to do). I got 5A/250V 20mm fuse from RadioShack and, expecting that this could happen again, I also installed a simple (5A/250V-rated) automotive fuse holder (also from RadioShack) (the only fuse holder that was available at a local store) and it works wonderfully now. Should the fuse blow on me again, I should be able to replace it in less than 3 minutes.
Feb 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Tv keeep blowing the fuse
simpel fix replace the 4 bridige diodes.\
parts cost about $8.00 and labor shold be about $60 shop around for best repair shop pricing.
Jan 11, 2009 | Sharp 27R-FS1 27" TV
Won't power up but the red light is ON
http://www.newark.com/littelfuse/0215008-mxp/cartridge-fuse/dp/42K9308
Fuse is a "Littelfuse 0215008.MXP"
8A 250V Slow-blow ceramic
Jun 18, 2008 | Insignia LCDTV26 26 in. Television
Fuse T1.6L250V
The fuse which you have used is of correct rating 250v/5A, the switching regulator of the SMPS primary section is faulty, so the fuse blows of continously
Dec 22, 2007 | RCA DRC200N
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
LG MU-42PM11 47 in. EDTV-Ready Plasma Television Logo
360 people viewed this question
Computer Repairing
Computer Repairing
