Question about Nokia 6265i Cellular Phone
My Nokia 6265i problem may be the LCD or software
My Nokia 6265i is opening and closing right back. No visual on LCD screen.Just it lights up, turns on then after a couple of minutes it goes blank. Sometimes it would give a message saying "Enter your code" I do it blankly but it never works. Please let me know what to do. Thanks
How do i flash my nokia 6265 mobile
To update(flash) your phone,best and easy way is with Nokia Software Update(NSU),you must use Nokia Ovi Suite to back up your from your phone,it's really easy to use it.after you install the programs connect the phone to to your computer via usb(use PC suite connection),back up your phone with Ovi,then close the program,open NSS and update(flash) your phone.Very important:Your phone must be fully charged and must not be disconnected after the update(flash) has began until is finished,else your phone will not startup.Here are the two programs:
http://europe.nokia.com/support/download-software/device-software-update
Feb 19, 2011 | Nokia 6265i Cellular Phone
How to obtain the imei number on nokia 6265i phone
You are asking for your mobile imie number?
Then you just switch off your mobile phone, open the back panel of your phone, then remove the battery(see phone manual for the isntruction to remove the panel)
You can see the details of your phone inside the phone.
you can see the imie number too.
You can also dial *#06# to see yor imie number
If you have any doubt, Then reply here
Thanks
Regards, Ashraf
Oct 27, 2010 | Nokia 6265i Cellular Phone
My nokia 6265 turns on but then turns itself off after 5 seconds
there is a software problem. firstly hard format it by pressing *3call buton then press starting button.it will start formating.
Dec 11, 2009 | Nokia 6265i Cellular Phone
The phone shuts itself on and off. Won't stay on beyond about 30 seconds.
The software in these phones gets corrupt, the solution is to get it reflashed at a dealer. Usually what causes that is low memory due to fillingit with pictures or video or if the video setting is changed to max length. They will also act up if the slide is only opened part way then closed without allowing it to get a full menu.
Jun 06, 2009 | Nokia 6265i Cellular Phone
My nokia 6265i phone powers up plays the nokia tune but the screen is blank.. Its lit up just no pic.. I can use the phone. meaning make calls and such but no pic.. I even replaced the Lcd screen
Try installing a theme or use the default theme. Oxycube works with this model of Nokia for uploading and downloading files such as themes etc. To use it U need a data cable and the correct usb drivers. These phones have problems if they do not have enough memory and also problems if the video is set to max.Howard forums has some info on them.
Apr 29, 2009 | Nokia 6265i Cellular Phone
Nokia 6265i
The default security code is simply 12345 and should work unless changed by your friend or MetroPCS. Hope this helps, if not, you may have to hard reset the phone. I will not explain how, but you can google it easy enough. Good Luck!!
Feb 14, 2009 | Nokia 6265i Cellular Phone
Nokia 6265i white screen
usually a software problem, needs re programming by a nokia approved dealer
Aug 18, 2008 | LG Shine CU720 Cellular Phone
Nokia 6265i feezing with white screen and turn off again?
this is the conflict between 2 softwares in phone. Try this Solution.
1.Charge the Battery to Maximum.
2.Hold *,Green(Answer Button),3 Simultaneously and press the power button on.
3.Hold this key combination untilll "FORMATTING. . . " Message will appear on the Screen.
4.Wait untill the formatting of handset is completed.
I hope your problem will be solved By doing this.
All the best.
Thank You.
Apr 02, 2008 | Nokia 6600
Nokia 6265i freezing issue
I've had the exact same problem with my nokia 6265i for almost a year now. I bought mine at Future Shop, so their express exchange program has now sent me my fourth nokia of the same model because I've had the same issue with every single phone. Clearly there is an issue with this model. If you bought it from Telus they may have a different program when the phone is still under warranty. If it's not, then Telus gave me two options. 1) get $100 off of a new phone (at non-contract p[rice) and renew your 3 year contract with Telus. (oh goody!) or 2) They are offering a samsung phone.. can't remember the model, you can phone them. But they are offering that for $80.00. In other words.. the phone is useless, and you will still end up forking out money either way. Telus will not make up for this. They told me to contact Nokia about the phone. I don't know how that could possibly help my situation. I'm done dealing with them until next month when the Nokia breaks down again.
Mar 30, 2008 | Nokia N95 Cellular Phone
Nokia 6265i cell phone
Not a solution but I can tell you that i have this problem and it started when i bought the after market charger from verizon.
Sep 04, 2007 | Nokia 1100
Nokia 6265i Cellular Phone Logo
157 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
