Question about Troy Bilt 5.5hp Self Propelled Mower
I have a snapper classic lawn mower 25th aniversary model engine model #124702 how do i replace the pull start rope
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
  • 420 Answers
SOURCE: ROPE ON MOWER WON'T PULL OUT
I agree, it sounds like the mower is fouled with foliage at the blade. Pull off the spark plug wire and tilt the mower on its side opposite of the carburetor, check the underside of the mower for impacted grass clippings.
Posted on May 14, 2009
MOTORWIZJ
  • 1368 Answers
SOURCE: engine doesn't stay running
99% ITS WATER IN THE GAS
Posted on May 21, 2010
  • 548 Answers
SOURCE: I have a Troy Bilt 675 lawn mower, won't start.
is the gas in the tank old? if so, try to drain it and put fresh gas in. Pull the spark plug to make sure it is not fouled and replace it or put in a new one. Check to make sure that you do not have the mixture or choke set to run too rich or too lean. If you are at an altitude above 2,500 feet you need to run more lean to compensate.
Posted on May 30, 2010
SOURCE: snapper riding lawn mower won't start
my snapper riding mower will spin but will not start. It was o.k. when I parked it a week ago. Now it won't start 28115BV
Posted on Nov 26, 2010
21" snapper self propelled mower
You need to remove the starting mechanism and make sure that there are no kinks, etc. in the starter rope.
Jun 12, 2016 | Snapper Garden
How to start it
      Stand behind the lawn mower. Use one hand to hold the engine stop lever in the operating position. Use the other hand to hold the recoil starter handle. Slowly pull the recoil starter handle until resistance is felt, then pull quickly to start the push mower engine.
      How to Start a Lawn Mower ' Starting Snapper Mowers FAQ
      www.snapper.com/us/en/support/.../how-do-i-start-my-snapper-lawn-mowe...
    Feedback
    How to start the lawnmower - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=QsRwZZwO4oc
    May 25, 2012 - Uploaded by iScaper1
    Tips on how to start a lawnmower. I asked my wife and boys today if they could start the lawnmower. One son ...
    How to Start a Push Lawn Mower: 7 Steps (with Pictures ...
    www.wikihow.com > ... > Lawn Care
    wikiHow... there's more to it than that, especially if you want it to keep running. Of course, how to start your individual lawn mower may vary according to what brand and...
Jan 12, 2016 | Garden
I have a inteck briggs motor on a snapper 30inch mower it has a battery start and a pull rope start it has startd with 2 pulls as the battery is over a year old thts why i have been using the pull start....
test the battery
if it is under 12v as normal change it; 10v is one dead cell. 8v is two dead cells etc.
if it is not able to hold a charge the engine wont start even with the pull start due to electronics not firing at under 12v
that is probably why it starts with the charger hitting it with 14-18v
Oct 10, 2013 | Garden
My yard pro lawn mower will not start, when i try to pull start it the crank rope vets pulled back sometimes
Two things to check here, check the blade is tight, it acts as a flywheel so needs to be tight, second, check the flywheel key has not sheared as this will cause the engine to kick back as the timing will be out.
Apr 25, 2012 | Garden
Pulled the cord out of the mower trying to get it back.
you have to remove the top of the mower and you may need to buy a new spring depending if it broke or not, then wind the spring up and slide the rope back through the holes and tie a knont in the rope and let the spring wind the rope back in. reassemble the top on to the engine.
Jun 16, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
I have a Snapper Briggs & Stratton lawn mower Model Series 126T00 and for some reason it will not start.I drained the gas tank ,put fresh gas in it. I did a caburetor kit and it still will not start....
How about the key way? Its the timing of the motor. Its under the pull rope and the wheel under the pull rope. Might be cut or broke in half.
Mar 21, 2010 | Garden
Lawn boy mower bought used wouldnt start then the rope broke
there are 3 bolts that you remove and thatwill allow the coil houseing to come off pull off buy new rope and wind the rop onto the rope holder then roll the spring to it's tighest postion put pull handle on and tie know it rope burn the end of the rope with a lighter to keep it from comming apart, be sure to thread the rope threw any holes before tieing knot. then replace it back on and bolt it together. and your set.
Jun 22, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Troy Bilt 5.5hp Self Propelled Mower Logo
572 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
