what to do when we do not get default gateway when we perform ipconfig.in windows ?
Comments:
Jan 11, 2008
- it does not work on ...
there those check boxes were already ticked
Jan 13, 2008
- its a broadband (PPPoA )connection.
Q.2.
Why everytime when we click on send and recieve we get the username and pass box :type in the username and pass but still it comes again and again .How to resove it ?
Thanks
Jan 14, 2008
- it does not resolve my problem .I am still not able to connect to the internet because there is no default gateway and i am not able to configure the router
-   I have the same problem.. When i plug my router to my computer, it will not connect to the internet.. And when i use ipconfig on cmd, there is no default gateway... My auto-config ip starts with 162. What can i do to make the router work? OUr connection is through broadband internet... Thx.. =)-   n4m3l3ss
You most likley have your Local Area Connection TCP/IP settings incorrect.
In windows XP go to > Control Panel > Network Connections > RIGHT CLICK on Local Area Connection > Properties > Click on Internet Protocol (TCP/IP) > Then properties > Make sure that "Obtain an IP address Automaticly" and "Obtain DNS server automatticly" are checked. Once you make the change, Reboot and you should be good to go.
Comments:
Jan 10, 2008
- Did this solve your problem?
Jan 12, 2008
- Then your device is not handing you a gateway address, are you connecting with a broadband connection (PPPoE) on your computer? What type of connection do you have?
Jan 13, 2008
- Ok so the broadband connection is the reason you do not havve a gateway address.
Jan 13, 2008
- If this information helped you please rate the solution as Fixya or helpful
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,...
(More)
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas, access points)?
Stability and reliability are also critical
We use a comcast cable modem
Must support mixed environment - 2 Macs connecting wirelessly, 2 PCs (1 with a wired connection)
We all want to be able to share a printer (which will connect to router with a wired connection)
Network attached storage, media streaming - I'm not worried about these now, looking for basic connectivity. Though would be great if I could grow into this in the future...
My ipod touch will not connect to my home network, but will connect to other networks. The Apple...
(More)
My ipod touch will not connect to my home network, but will connect to other networks. The Apple tech support person said that the problem must be with the router. What can i do?
Router won't reset and is not pingable. When reset and re powered up, all the lights are green...
(More)
Router won't reset and is not pingable. When reset and re powered up, all the lights are green immediatley (except wireless) so not going through any boot up.
