Question about Bosch Washing Machines
Hi, I have a Bosch WFP 3201 and it is displaying an error code FO5, could you please explain what this means. Thanks
5 Suggested Answers
SOURCE: bosch washing machine error code
e04 error not draining door won;t open
Posted on Oct 22, 2008
SOURCE: error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Posted on Mar 10, 2010
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code F 23
F23 that it indicates a leak into the base of the appliance.
You'll need to unplug the appliance and take the rear cover off.
Check for a spillage and if there is an anti flood device in the base, ensure it's reset/working or replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
What does Code E:00 mean on a Bosch washing machine 7kg WAK2020SME?
It is strange, but this error code should not exist.
I found a youtube film, explaining most codes and what you can do to solve it. Take care, when you don't have the correct skills, ask a tech.
How to Identify an Error Code on Bosch Washing Machine
Apr 26, 2015 | Bosch Washing Machines
How to use the delay timer on my washing machine
Each time you press it it changes the amount of time before the chosen program will be finished
eg 4hr means in 4 hours the cycle will finish
Sep 27, 2014 | Bosch Washing Machines
Code error F05
If this is a Whirlpool model the FO5 error code means:
Water Temperature Sensor Error
If during the water heating step in the wash cycle, the water temperature sensor
(NTC) value is out of range, or the heating element circuit has failed, the "F/05" error
code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
F/H
F/02
Hope this sheds some light on your problem
kcomp1863
Jan 20, 2011 | Washing Machines
F 05
Hello,F05 means that the pump is not getting rid of the water.
You to locate and clean the filter, and or check the pump for a blockage or restriction.
Thanks
May 23, 2010 | Hotpoint Ultima WF860 Front Load Washer
I HAVE F -05 DOES NOT RELEASE WATER CAN YOU HELP
FO5 means pressure switch (9 water level switch) jammed on full.
Check pump filter and pump for possible blockage.
Pump and filter to be found at rear bottom right of washer, remove panel to gain access.
Please rate my solution.
Thanks.
Aug 09, 2009 | Washing Machines
Error code F 21
Apr 05, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
