Question about Gemini SA-600 II Turntable
When I put an album on it skips for the first few songs then plays fine. The records are not warped. could something be wrong with the turntable. It happened with 5 or 6 albums I tried.
  • 189 Answers
HELLO
Make sure you have the deck set up correctly! Check the headshell - is the cartridge out of alignment or is the stylus worn?
Also, it may be that the counterweight is set too lightly for the cartridge and check the anti-skate control as well (example if the arm is tracking at 2 grams, anti-skate must be set at 2).
Follow these instructions for setting the counter balance:
Turn the weight so that the arm is just floating then set the balance ring (with the numbers on) you will see there is a line. Turn the ring not the weight to the ZERO mark where the line is on the top of the arm. Now turn the weight and ring together where it moves forward down the arm and set it at about 2 grams.
Now set the arm using the height adjustment that is the ring fitted to armboard and make sure the arm is straight (if not, the stylus will mistrack). Now try the deck again. You might have to make adjustments to the tracking weight again so whatever you have it set to, set the anti-skate to the same!
Good luck with it (:-)
Posted on Nov 15, 2009
The tone-arm on my turntable automatically stops too early. Is there any way to fix this?
Yes. you need to set the travel on your arm. I don't know your specific model but they are all the same concept. On the back by the pivot point there should be a small screw that you can adjust the travel before it returns.
Dec 31, 2015 | Audio Players & Recorders
Turntable skips regularly
Once adjusted to the correct weight for the type of cartridge then the arm should only jump on a bad record. If it keeps on jumping then either there is something wrong with the platter, being warped or a bad matt. Or there is something in the mechanism that is causing the jumps. Either of these two causes is possible if it does it in the same position on two different records.
Mar 05, 2014 | Technics Audio Players & Recorders
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
Every record skips in different places
You should look for an anti-skate control on the turntable and adjust that. It will be a question of trial and error with it as there is no fixed rules for these. The weight on the back of the arm should be set to the weight of your cartridge.
Dec 11, 2012 | Sony PS-LX300USB Turntable
When I play an Album, it will play say 2 songs then on the 3rd song it will come up 'Finished Recording' it seems to only do this when it feels like it. Thanks Erika
what exactly are you trying to do just play records or dj with this? and what software are you using thats saying finished recording? Are you even Recording anything? please let me know
May 17, 2011 | Numark ttUSB Turntable
Jensen JTA 450 turntable skips?
Try moving the arm up to the end of the vinyl, if it does go till the end of the vinyl then try adjusting your counter weights, a penny will do, if it doesn't go till the end of your vinyl then there's a mechanical problem check any obstruction at the botton of your arm.
Jun 09, 2010 | Audiovox Jensen JTA450 Turntable
I have a mid 1970s Sears turntable with am/fm, casette, and 8-track. It plays older vinyl just fine and even one new 45 but my new 33 skips a lot. Could it be the record, do I need a new needle, any...
My suggestion is ask a friend etc with a turntable to try the new LP and see if it bounces on there's. If it plays your old stuff it most likely doesn't need a new stylus. Records are records they don't make them any different to what they used to. Check the new LP, is it warped does it have marks where it jumps?
Sep 17, 2009 | Audio Players & Recorders
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
Jun 23, 2009 | Audio Players & Recorders
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
No matter what I do, I can't eliminate the occasional skip...
Try cleaning that lp with an anti static felt record brush, and look for either groove glide or d4 cleaner....Sounds odd, but ive ad records kept in tip top, climate controlled, and funk still gets in the groove.
Oct 29, 2007 | Audio Technica AT-LP2D Turntable
Gemini SA-600 II Turntable Logo
222 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
sean tan
Level 1 Expert
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
