Question about Samsung U900 Soul Cellular Phone
Everytime i conect my samsung soul to the computer via usb cable it says connection enabled.But i dont no why? can u help me
Can I connect canoscan 4400f using ethernet cable
i believe is not possible to connect to a router. printers ar designed to be connected to computers via ethernet cables and bluetooth when both devices are bluetooth enabled.(must have a wifi bluetooth ethernet card installed or usb bluetooth installed via usb). is you want to have the printer to be used bye more than one computer at home or office. you must set up each computer to the printer as well.. in control panel look for printers.then set up the conections.if computer 1 is printing a document. computer 2 will have to wait. when done. then will print work for computer 2.
Dec 18, 2012 | Canon CanoScan 4400f MultiFunction Color...
Samsung ES28 Digital Camera - no connection with PC via USB
have you tried connecting other memory drives with your computer? maybe there is a problem with your computer's hard drive. If the other devices can be connected, then check your cord for an damages and get a new one perhaps
Apr 03, 2012 | Samsung Cameras
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
Not conected to my pc right
Hello Sir =D
There is the easy way to connect your phone with computer
1) you need a Usb cable To connect it with computer
1-1 ) you need to configure your cellphone : If There's a memory card on your cellphone Try This Way
1-1-1) Connect your phone via Cable , a new menu will appear on your cellphone screen , choose data transfer
2) if there isn't a memory card , so you need this application : samsung pc suite
Download Link , Install it
Then connect your cellphone Via Cable , a menu will appear on your cellphone screen , choose samsung pc suite ^^
Accepte My Greetings
May 02, 2011 | Samsung Galaxy S GTI9000 Smartphone
How connect samsung champ GT-C3303 to pc suit via usb cable
my mobile model no is samsung GT-C3303,I have activated gircel poket internet but not to conect my pc via usb,pls suggest the solution
Feb 22, 2011 | Samsung Computers & Internet
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
I cannot connect to Samsung GT-S5230 from PC via USB
How to salve a ******* problem with Samsung Pc Studio
Aug 26, 2009 | Samsung U900 Soul Cellular Phone
Cannot connect Samsung GT-S5230 tp PC
TRY TO CHECK THE SETTING OF YOUR PHONE REGARDING CONECTIVITY.
Aug 21, 2009 | Samsung U900 Soul Cellular Phone
Canon MP170 - Computer re-booting
Hi nens..! is your printer ok..? try to connect your printer to another usb port, if not change your usb cable, maybe there's something wrong with your cable.faulty cable keeps your computer restarting. Hope this would help..
Oct 02, 2008 | Canon PIXMA MP170 All-In-One InkJet...
O2 xda 2 mini pocket pc usb connection problem
hi, i got the same problem, i even got a new sync and tried different ways to sort out but same problem??
email me plz for help
kind regards
Jul 13, 2008 | O2 Xda II Smartphone
Samsung U900 Soul Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
