Question about Motorola Mobility SIDEKICK SLIDE Cell Phone
My face on my sidekick dont trun and a red light comes on
I have a samsung 42 inch plasama ty model spp4231 when i try trunin it on the red light comes on it blinks 5 times them truns offWhat's your problem?
Hi the blinking light is a code. The service manual for this TV will have a description of the code. do a google search for the service manual and download it.
you can get parts for this tv at www.interliquidparts.com
Feb 24, 2012 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
Insignia 37 in lcd, trun on light gose blue
It is the main board failure, because Insignia TV has no error blink design.
May 10, 2010 | Televison & Video
Dont work but red light still flashes
your charger may be broken try using another usb charger.
Aug 12, 2009 | HTC G1
If my sidekick is refurbished and it charges but dont come on what can i do?
the Sidekick 3 has a charging issue that cropsup after awhile. The charge port gets broken and It will just not charge the battery. A good way to tellis if the orange light comes on but the phone never charges.
If you have a friend that has a sidekick 3 or sidekick ID, try their battery in your phone to see if it powers up.
Youcan get an external battery charger for the sidekick for about 25dollars that will allow you to charge the sidekick 3 battery separate.
Check out the following link to see what I am talking about.
Sidekick 3 external battery charging cradle
Jul 14, 2009 | T-Mobile Sidekick® 3 Cellular Phone
1990 suzuki sidekick red light comes on dash
check your power steering fluid,
sounds like it would be low on fluid
May 08, 2009 | 1996 Suzuki Sidekick
Sidekick 3
If the orange light is coming on, but not charging the sidekick then the charger port is probably bad.
It's about 80 dollars to fix at cellulardr or you can do a work around and charge the battery seperate from the phone.
check out the charging cradle here:
Sidekick 3 spare battery charging cradle
Dec 13, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Lights don't turn on
You need to replace you LCD. About 50 bucks from ebay. most come with good instructions and the screwdriver. You will need a T6 Torx driver to open the LCD.
http://shop.sidekickskin.net/SideKick-Repair-Parts/Sidekick-LCD-Screens
Jun 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
PLZ HELP SIDEKICK 3 SCREEN WENT RED AN GREEN
reylakers-
You can try and reset the flex cable on the lcd.
follow these instructions.
Fix Sidekick White LCD Screen
If that doesnt work then a new lcd screen unit will.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-LCD-Screens
Jun 08, 2008 | T-Mobile Sidekick® 3 Cellular Phone
TV PROBLEM
Check if your rca'c havent got short. Otherwise you must open youtr tv , check where your convergenge ic's is , there is 3 plugs near the convergenge heatsink. Plug it out. if it stays on you must change your convergenge ic;s
Feb 20, 2008 | Samsung HCN436W 43" Rear Projection...
Motorola Mobility SIDEKICK SLIDE Cell Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
