Question about Cobra 29 LTD CB Radio
Have cobra 29 nw ltd keeps blowing fuses inline and in cigarette lighter adapter adapter is 10 amps and inline is no more than 5 amps
    Guru:
  • 773 Answers
This is an easy fix if you are comfortable soldering.
You must have hooked it up backwards. Big problem when using a cigarette lighter adapter. You have to be careful, if you hook a radio up backwards you blow the polarity protection diode.
  • Go to radio shack and buy an N1004 diode.
  • Open the radio
  • Look towards the back right of the radio for a black diode D23. it will probably look burnt, but not always.
  • Use a soldering wick to remove the solder holding the diode in.
  • Remove it, and replace the diode making sure its going in the same direction as the old on. Strip on the side the triangle is pointing.
  • Solder it in.
  • Test the radio
That should do it.
Make sure you are careful to hook the radio up to power corrctly.
Posted on Nov 20, 2009
I have had a Cobre 29 LTD Classic, a 29 NW LTD Classic and now a 29 LTD Chrome.It seems that the first two died because of possible bad antenna connections. I was able to calibrate the radios and adjust...
I see two possible problems. First, with a magnetic antenna it is difficult to get the proper ground for the antenna. Make sure the magnetic base is clean as well as where you place it. Second, try running your power lead DIRECTLY to the battery and not using the cigarette lighter. Hope it helps.
Tom
Feb 27, 2013 | Cobra 29 LTD CB Radio
FL 2000 freightliner fuse box diagram
use a cigarette lighter plug ,its safer.
Oct 06, 2012 | Cobra 29 LTD CB Radio
What size inline fuse is in the cobra 29 wt nw
Usually a 3 amp quick acting 3AG fuse---do not use the generic ones from Radio Shack.
If the radio got hooked up backwards look and test for a dead short across the power leads-----there is a diode just inside where the hot lead goes that will be shorted .
SD TECH
Apr 21, 2012 | Cobra 29 WX NW ST 40-Channels Base CB...
How to fix the dimmer light ona cobra 29 nw ltd classic
HI I AM TRYING TO FIX MY 29 COBRA LTD IT WENT OUT ON ME
Feb 04, 2011 | Cobra 29 LTD CB Radio
Low transmit audio cobra 29 ltd nw
Are you talking about this radio or what others are hearing from your radio?
My friend, no one but the holder of a 1st class FCC radio license is permitted to adjust the input power to the final amp. Further, one needs some pretty technical equipment to accomplish this fine tune adjustment. Failure to properly set this envelope will result in degraded operation and possible failure of your radio.
If you can't live with the present circumstance, get your radio profesionally repaired.
Thank you for your quesiton at FixYa.com-
Jan 06, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Cobra 29 nw ltd won't transmit
Have you cracked the radio open yet?  check for loose connections etc.  get back to me if that doesnt yeild any results
Dec 23, 2008 | Cobra 29 LTD CB Radio
COBRA 29 NW LTD CLASSIC
Capacitor C-82, which connects the output of the driver to the input og the final, is leaky or shorted, putting +12 volts on the base of the final, which blows it immediately.
Mar 28, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
838 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
