Question about Brother MFC 8820D All-In-One Laser Printer
The flatbed lid on my 8820D has a broken hinge in the back. What are sources for the hardware parts so I can repair it myself?
    Problem Solver:
  • 6 Answers
I purchased a direct replacement from e_techparts on ebay for under $10 + S&H, very simple replacement, just a few screws. It's even available on Amazon. Part # LP2403001.
Posted on Apr 30, 2010
Lexmark 7600 printer cover is not seating properly after installing printer cartridge
The two hinges are attached to the back of the printer by two screws. I removed the two screws and lifted the top off, freeing the two hinges (the one on the right was broken so part of it stayed in the printer). There is a restraining line on the right side that keeps the top from coming completely free of the printer, but it can be worked around while still attached. I removed the broken pieces and the internal spring from the right side hing. The spring is what was keeping the top from seating correctly. I assume you could order a new hing, but I reassembled the printer without the spring and the top seated properly. The printer works, but I will now need to be very careful when replacing the ink cartridges because of the missing hing on the right side.
May 10, 2011 | Lexmark International Lexmark 7600 Series
Can't close doc cover properly - seems 'broken' at hinge - can I fix this myself?
The left hinge breaks often enough that Brother changed the part number of the part. I hope that means the new part is stronger; I haven't seen one come back for a second repair. Assuming it's the larger, left hinge that's broken (It always is.), you need an LP2403001 HINGE ASSY L. You can find it from a servicing dealer or online, and it's easy to replace.
Look at the back of the machine and find two large phillips screws in holes. They keep the hinge blocks from coming up all the way out of the machine. Remove both of them and lift the top cover up until it's connected only by its cable. It might take a helper to hold the cover, but you need to unscrew the hinge assy. from the top. The three screws are obvious and easy to reach now that the cover is loose. Put the new hinge on, lower the top back down so the hinges drop into their holes, and put those screws back into the holes in back. You're done.
Jul 11, 2010 | Brother MFC 8820D All-In-One Laser Printer
I need a source for a replacement attachment compartment lid on a model #544 Artico. The hinge pivot have broken.
Hello. Any local vacuum repair shop can get that part for you or you can order it on the internet at this link
http://www.govacuum.com/miele-bag-chart.html
Feb 13, 2010 | Vacuums
My printer says doc cover open on a mfc 8820d how should i fix.
You have to close the ADF. If the ADF is closed, then the left hinge is probably broken. Look for "MFC-8820D hinge" to find the solution in FixYa.
Jan 10, 2009 | Brother MFC 8820D All-In-One Laser Printer
Unit says Doc feed open. After checking many times it appears closed but can't clear the message and swith from fax to copy
raise the lid and hold the black pin down, located on the left back underside of the lid. your left hinge is probably broken or cracked causing the lid not to go down all the way.
May 26, 2008 | Brother MFC 8820D All-In-One Laser Printer
8820DN hinge problem
To answer Meyerson's questions:
My symptoms did not include papers jamming in the ADF -- in fact, the ADF didn't work at all due to the broken left hinge.  :(  Also, I don't recall having any unusual problems with the ADF jamming frequently before the hinge broke to the point where the ADF didn't work at all.
I obtained the replacement ADF left hinge assembly by searching online for a parts dealer.  I believe I ended up ordering the part from Precision Roller.
I hope this helps,
-Barb
Apr 01, 2008 | Brother MFC 8820D All-In-One Laser Printer
Parts for Brother MFC 8200D
Yes, I had the same problem in Sept 2006 - a broken left hinge that needed fixing. Ordering the part was easy. I was able to install it myself, but it required some attention to detail.
I called Brother International at 800-284-4357, Option 1, then 2. I ordered the left hinge - Part No: LP-2403001 - described as ADF Hinge Assembly (left). If you broke the right hinge, the part number may differ slightly, but person on phone should be able to assist. It cost me $11.55 including shipping.
Feb 28, 2008 | Brother MFC 8820D All-In-One Laser Printer
Brother MFC 8420-- hinge?
i went to Brother site and opened support.
searched for parts and got a listing of technical support shops in my area. called the first one listed and asked if they had the LP2403001 hinge in stock and they came back with an affirmative answer. will pick it up this afternoon locally.
You can see an image of the hinge assembly at ebay if you search for LP2403001.
Regards,
David
Jan 25, 2008 | Brother DCP-8020 Laser Printer
How to replace broken hinge on ADF on Brother MFC-8820D printer
Look at back of machine and at your new hinge, note the screw hole, if you undo both of those on the back of the printer, entire doc feed will come up and out, BECAREFULL just lift A LITTLE is enough to enable hinge base to be free of sockets (many cables attached) and place doc unit slightly sideways on copy glass to enable yourself access to 3 screws that hold hinge.
Jan 05, 2008 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 8820D All-In-One Laser Printer Logo
123 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
