Question about Braun Food Processors
Hi there, I have Bruan Multipractic 4258 with motor fine but hard plastic casing on drive shaft spindle fractured. Any chance of getting replacement for just this part, please? Have tried hard epoxy repair - but fear it will not work or last. Many thanks, Colin Bevan.
  • colinbevange Nov 14, 2009
    Still looking for replacement hard plastic covered drive spindle for fairly vintage Braun Multipractic Model 4258.
    No replacement part found on Braun websites.
    Anyone any ideas please?
    Manuy thanks, in anticipation.
    Colin Bevan
  • 6,826 Answers
Go on line and type in bran food processor parts,and click,there will be choices of where you want to order one,on line,I hope this was helpful,and if so,please let us know,thank you.
Posted on Nov 15, 2009
  • Braun Master
  • 19,396 Answers
Hi.
Epoxy is not a good solution, in the best case the part will break again because of vibration.
Third party websites do not have the part in stock anymore, here a website:Braun food processor parts.
The only way to find out if the external casing is available is contacting Braun Parts.
Here the link to Braun Service website. Select your region and follow instructions.
Regards.
Posted on Nov 14, 2009
Can I change the plastic motor spindle on a magimix 5100?
Yes you can, you can "cut" it off with a soldering iron by melting a slot down one side. When banging a new one on you need to remove the base and suppert the bottom of the shaft with something solid underneath it. The whole motor assembly will be sitting on this as you bang the new sleeve on with a soft mallet. If you don't there is a danger you will wreck the motor and you cannot afford to replace that bit.
Aug 29, 2014 | Magimix 5100 Cuisine Systeme Food...
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
Spindle jammed on the stem
The motor shaft sleeve and spindle will need to be replaced, once this jamming has happened it becomes ongoing if you do not replace those inexpensive parts. You need to wrap some webbing tightly around the spindle attach the other end to something very solid (like a fence post) and then accelerate the motor part rapidly away from the post. Hold onto the motor very firmly or it will land on the ground.The webbing tightens instantly when it runs out of slack and the spindle will come off. Then you need to remove the motor shaft sleeve in a similar manner, I drill a hole in the end and use a shackle and chain attached to the post for that one. I use the leg of my workshop bench, most folks will not have a solid heavy bench like mine. If that sounds too hard just take it to your local K/A service agent, they will have done it many times.
Sep 10, 2012 | KitchenAid KFP750 Food Processor
Kitchenaid kfpw760 blade stem is stuck
May 26, 2012 | KitchenAid Food Processors
Cracked plastic sheath on the motor drive shaft
The shaft is spinning inside the sleeve. So is should not be hard to remove. With a DLC-7SP, I grabbed the spindle with some pliers, channel locks might do well and put a handle of a screwdriver between the pliers and the top deck and pried. Second attempt and it pulled up easily. Place the screwdriver beside one of the top deck screw covers to transfer force directly to the motor. Otherwise top deck would probably break.
Clean the old shaft to remove any contamination.
New one can be driven on with a hammer and block of wood.
Jul 08, 2010 | Cuisinart DLC-7SFP Pro Food Processor
My Hamilton Beach Food processor model # 702-1 has a BROKEN plastic gear that attaches to the motor drive shaft (it threads onto the shaft). It meshes with another plastic gear that turns the spindle that...
my suggestion is that watever spare part u replace, get it replaced by the original manufacturer to avoid future problems. take it to the shop you have bought it from, ask them where u can get one. they may help u better with contacting the manufacturer. i know its time consuming! good luck!!
Oct 14, 2009 | Food Processors
Braun multipractic food processor model 4259.. Need the insert carrier. Spindle post from bottom to flange is 1 3/4 inches. Where might I find one? What kind of plastic is it made from? Would an epoxy or...
The disc carrier you're looking for is Part No 7002058 (the number may be stamped somewhere on the holder itself). It's like a circular/figure 8 kinda looking thing on a shaft. If you're in Australia I'll be able to help get spares.
Don't recommend using glue to repair due to stress breaking it again, and for food safety issues.
Mar 30, 2009 | Food Processors
Magimix sytem cuisine
Jul 02, 2008 | Magimix 5100 Cuisine Systeme Food...
The spindle (middle thingie) is broken
I don't know about the little lip you're referring to, but the central spindle that comes up from the base of our KitchenAid 12 cups food processor KFP750WH0 splintered and broke while we were using it. We ordered a replacement motor sleeve shaft part number KA8211849 from the Gourmet Depot for $4.95 plus $3.50 s/h. Removing the broken plastic sleeve shaft was the difficulty; it isn't glued or screwed on but somehow it didn't want to be pulled, pried, or cut off. With the help of our neighbor fix-it man and all four of us working at it with screwdrivers, we got the old broken part up and off. Pushing the new one onto the metal motor shaft was easy, and it was fixed!
Jan 16, 2008 | KitchenAid KFP750 Food Processor
Food Processors Logo
70 people viewed this question
Top Braun Food Processors Experts
eyecam
Are you a Braun Food Processor Expert? Answer questions, earn points and help others
