Question about BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620
No signal for my lcd projector
Got a mitubishi lcd projector today with no instructions. have the cable from my computer. have tried both ports computer in and monitor out ...power on no signal suggestions, not computer savy : )
  • Anonymous Feb 20, 2008
    can't get the signal between my laptop and the projector.
    Help please!
  • manjee Feb 25, 2008
    I found there is no display from the projector. Everything is connected properly, and there is power to both the laptop and the projector. How to get the display to work.
Have you tried replacing the projector lamp? This company has all the lamps in the world:
Posted on Apr 11, 2012
    Problem Solver:
  • 6 Answers
You have to "Toggle" your PC to output the signal to the projector.
On which "F" key do you see "CRT/LCD" or a pictute that looks like a monitor?
Posted on Jan 18, 2008
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
Colour dispaly problem in LP 640
are you useing SVIDEO out from your pcs video card to connect the image to the projector?
have you set your pc to send video out correctly?
It seems your pc is not sending correct video / settings wrong.
Or then there is a problem with the projector. Try a difrent input?
Mar 29, 2008 | InFocus LP 600 Multimedia Projector
Sharp Notevision PG-C30XE problem with computer display
There are 3 different types of analog video signal ports on your projector; s-video, composite video, and RGB. Which one of the three are you using to connect your PC to?
The projector's resolution rate is XGA [1024 x 768]
If you are using a VGA cable designed and capable of handling 640 x 480 resolution; then it will not support XGAs 1024 x 768 signal. On the other hand, if the coaxial cable you are using is a multi band one that is capable of supporting VGA and XGA resolution signals, most likely the problem is not with the cable- although I have come across brand new cables that are defective.
Please let me know if this helps or else we'll try another approach :)
Nov 25, 2013 | Sharp Notevision PG-C30XE Multimedia...
Have an infocus litepro 580, lamp and speakers works fine. Projector will only show the "infocus systems" opening display without changing to my video source. All cables are correctly in,...
Go into the settings menu of the projector and turn off the auto source function, then select the input that you are using.
if using a laptop you may have to simultaneously press your FN and relevant 'F' key to send the signal out to the projector. The 'F' key usually has an image of two side by side monitors or it says LCD/CRT. Wait a few seconds each time for the signal to be sent to the projector. Sometimes you may have to repeat this action 3 times to get the image on both your laptop and your projector.
good luck
Mar 08, 2011 | Office Equipment & Supplies
Not receiving signal from computer (checked cable & setting)
1) make sure you are not plugged into the "analog out" port on the projector.
2) check the cable for bent or missing pins (there should be 15)
3) try changing the resolution on your computer...1024x768 is safest.
Feb 18, 2011 | Sanyo PLCWM4500L PROF PROJECTOR Projector...
I have a Hitachi CP-L500 LCD projector. It is connected to my laptop from the svga projector port to the svga port on the the laptop. It is making no signal connection. I have made sure the input button...
I am not familiar with your Hitachi LCD projector . However , I do have a little knowledge regarding video signals and inputs / outputs as well as connections . If your connecting cable is one piece (has no adapters added to either end of it ) I would believe your problem is simply a settings misconfiguration in your projector / computer , or both . First , access your startup BIOS / CMOS settings during the initial booting sequence in your computer by pressing F1 or whichever keys you press when you turn the computer on to access it . Then , in the advanced list , check your primary video input selection to be sure it is default. Then, once the computer is completely booted and you can click on your start selection , go to your video settings and check how to switch between internal and external display options . I say this because it is important that you are able to reroute your video signal to your SVGA Out from the laptop (for sure) and it is in fact in that video output mode. Once you're sure you have a signal going out of laptop through that port , go to your projector video input selections menu and select each and every input option available until the signal comes through . This will only work if you're absolutely 100% sure that your video signal is in fact leaving the laptop via the SVGA port connection .
Sep 05, 2010 | Computers & Internet
I can't get a picture when I hook my projector up to my laptop.
If your LCD or DLP projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F7 once: The laptop screen only
* Press Fn / F7 twice: The projector port only
* Press Fn / F7 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
Hope this helpout....
Jun 17, 2010 | HP Digital Projector Vp6110 Multimedia...
I am trying to set up an InFocus LP400 projector with my computer. I followed the instructions using the CableWizard Lite cable for my laptop pc and get no projected image. I used the suggested port...
start the connecting all over again, by following the steps below:
1. Turn your computer off.
2. Connect the cable from the computer to the projector. If you want to have your monitor to be hooked up as well, connect a splitter to the video out port (DVI or VGA). You can also just hook the projector up to the second port on your video card (If you have one) or if you have a laptop, you can connect to the video out port on the back.
3. Turn the computer on and boot into your desktop.
4. Turn on the projector. Most projectors have an auto detect function, that will detect a video signal and auto configure the projector to display that signal. If you have a laptop, you have to hit a function key to activate the second display. Usually this is FN Key + F5 or one of the F Keys across the top of the laptop keyboard. It looks like two squares, one empty and one with something in it.
5. Adjust the focus, brightness, contrast, and color on the projector.
6. Aim the projector at something white. Try not to aim it at something highly reflective.
7. Step back ... Load up your favorite game or video ... and enjoy.
Your project should work, after following the above instruction.
Good luck.
Apr 07, 2010 | InFocus LP 400 Multimedia Projector
Bad connection between laptop and lcd projector
First, check all plugs and make sure there are no broken or bent pins in them. If the projector you are using have a replacable cable try to replace it to see if the cable is the problem. (borrow a cable from a friend or relative first so you don't buy one if it is not needed.)
If that doesn't fix it, try to connect a different computer to your projector to see if that is better. If so, the output port on your computer may be bad.
Also try to hook your compuber to a different monitor to see if that works. If no computers are able to make a good picture on your monitor, the monitor is at fault.
The fact that you can change the picture quality by wiggling the cable, and that it starts to search for a signal suggests that the cable or the plugs are at fault, but having the wrong resolution set up on your computer may also affect the image quality. Again, try to use a different computer as a source to eliminate (or confirm) your computer being the problem.
Feb 19, 2008 | Compaq Presario 2140US Notebook
LCD projector no signal message
Usually means that the computer is not sending a signal out the the projector via the monitor cable. Most Windows based laptop computers allow you to connect to a second monitor by pressing the Fn + F7 or F8 key, once to allow just the projector, twice to allow both the projector and laptop screen and three times back to only the laptop.
Feb 18, 2008 | Office Equipment & Supplies
BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620 Logo
209 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
