Question about Samsung U900 Soul Cellular Phone
The gold ribbon thing came of - Samsung U900 Soul Cellular Phone
Error message E6 F2
From investigation, I would open the control panel (make sure the power is turned off first!) Look for a ribbon cable that goes to the Touch Pad and Control pad module. It should be able to be removed from the control board. Pull out the ribbon cable, and put the ribbon cable back into the connector. Be careful with the cable as they can be broken easily. Once you have everything back together, turn the power back on and test the pad. If it still doesn't work, the control board may be bad.
Nov 05, 2013 | Whirlpool Gold Resource Saver GGE390LX 30"...
Just replaced battery but dont know how to reattach ribbon cable on nuvi 200
flip locking flap on connector away from the gold pins. Slide the ribbon cable into the connector on the side with the gold pins as far as it will go. The ribbon goes face down with its gold pins facing down. Then using two fingers flip the locking flap down and toward the ribbon cable. It should click. Be careful, if you snap the flap it is game over.
Jul 31, 2013 | Garmin nuvi 200 Car GPS Receiver
Ribbon is disconnected
hi i had that ps3 b4 and yes that ribbon cable hooks up under your blu ray drive on the last input piece next to the skinny gold looking ribbon just push that flap up then put it in there and push it back down to clamp in the ribbon wire can i ask what you were doing this for
Mar 13, 2013 | Video Game Consoles & Games
I am getting a constant Ribbon stall on one of our p5010, we have totally cleaned hammer bank areas and put in new gold ribbons, we compare ribbon drag on the stalled p5010 to our many working p5010 and...
there are few things.. may be your ribbon hub damage... your ribbon motor not working properly.. check ribbon motor connection...and finaly L/C..CMX..CFX board.
Mar 10, 2010 | Tally Compaq Line Printer LG05 500 LPM...
How do I print using the foil ribbons? I do not see Gold foil as a color choice.I am interested in any info from a manual on this subject of gold or silver foil ribbon printing.
Your ALPS MD-5000 MUST be set to print in DYE-SUB. mode.... Is there a Memory upgrade plugged into the slot next to the Printer Port? If not, then it's not an option......
Feb 11, 2010 | Alps MD 5000 Thermal Printer
Have a hp all-in one officejet 7310. it just started telling me to remove an check cartridge on the right. new cartrige is same.
Look inside the printer at the ribbon which has the gold contacts on it which line up with the back of the black cartridge. There may be a small pinhole in the ribbon which indicates the little metal cartridge bar has pierced the ribbon. If this is the case the printer is broken. Check all tape has been removed from the cartridge and rub the gold contacts on the back of the cartridge with a cloth and try again
Dec 01, 2008 | HP Office Equipment & Supplies
Window shows "remove color cartidge and check" On screen dialog box states " color cartidge in wrong. I have had the HP V40 series since 2002 and never had this problem before. I have...
2 possible problems.
1 cartridge faulty or just needs a wipe
2 carriage ribbon damaged
Take the cartridge out and gently rub the gold contacts on the side with a piece of tisue. This might clear it. Take a look at the cartridge carriage in the printer and make sure the ribbon where all the gold contacts meet up with the contacts on the cartridge is not damaged in any way. sometimes the little metal spring which holds the cartridge pierces the ribbon at the back of the carriage and then the printer is unserviceable.
if rubbing the cartridge does not work and the ribbon is not damaged then assume you have a faulty cartridge - rare but it does happen
May 09, 2008 | Office Equipment & Supplies
DS Lite
Get new one or call nintendo 4 the # go to nintendo.com or google it
Nov 16, 2007 | Nintendo DS Lite Console
Ribbon Cable LCD
yes you can still do that but i think it would be best for you to take the phone to a professional mobile service center and have them replace it for you.
Sep 03, 2007 | Samsung SGH-d807 Cellular Phone
Samsung U900 Soul Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
