Question about Kenmore 65924 Electric Dryer
80 series will not heat up. Black red, green and white wires run from the power cord and the white wire is not connected to anything, could this be my problem?
  • 3 Answers
Not likely ... if the "pig tail" has 3 prongs that plug into the 220 then the extra wire is for the newer 4 prong standard that the industry has gone to. If the dryer is getting power at all this is not the issue.
take the back off after disconnecting your power course ( of course) and check your heating element... see if its clogged up. clean it all out, clear any loose debris and set it aside securely so that it wont accidentally move or shock you or cause a fire then turn it so you can see the exposed element.
Plug it back in and run the dryer.... if the element works then perhaps it was a dirty sensor or something ( there are a couple of sensors you will see that are installed in the side wall of the heating element, there is also a thermostat). If the element fails to heat, unplug the dryer from the power source and check the wires going into the element and its sensors, thermostat... if any of them look burnt or corroded near the female coupler ( wire will look black and toasty around the outside insulation closest to the connector on the sensor or w/e). Buy a new coupler and some heavy grade electrical tape and some wire strippers. YOU HAVE TO BUY HEAVY GAUGE FEMALE COUPLERS AND NOT THE THIS CAR STEREO TYPE AND YOU MUST USE HIGH GRADE ELECTRICAL TAPE CERTIFIED FOR 220!!... unplug the wire and remove the old coupler with wire cutters and strip back the insulation and inch or so to the bare wire and inspect the copper for any corrosion. once you find a good section twist it a bit and place it in the neck of the new coupler then use your stripping tool' front teeth to crimp the coupler onto the bare wire. make sure you have enough slack in the wire to connect it back to the sensor because they dont give you that much wire to play with and I would hate for you to have to replace the whole wire if you didn't have to. Next, liberally apply the electrical tape starting at the neck of the coupler and working your way down the length of the bare wire. You only need to use as much tape make it as thick as the rubber/plastic wire insulation that is already on the wire. Make sure you put tension on the tape as you apply it to ensure god coverage and adhesion.
Reconnect the wire(s) and make sure the element is secure and no lose debris is anywhere near any moving parts or electrical wires or exposed heating coils, then plug the pug tail bag into the 220 and start the dryer... if the element still does not work after the repair you should use a voltage tester on the sensors, thermostats and the element it self... then sensors are fairly reasonable and common sense you have a Kenmore but the elements vary greatly... a new heating element can cost $14 to $45+ dollars U.S.
Dont feel bad after doing the wire repair if it doesn't work because its worth your time. If the wire repair DOES work you are only out about 6 bucks like I said. But you just have to trouble shoot these things...
If you plan on keeping the dryer I would also suggest going ahead and replacing the belt tension pulley found under the dryer tub usually affixed to either the side or front panel or the dryer... it only costs about 7 to 15 dollars but if you have any age at all on that dryer those bearings in the pulley usually and commonly go bad making a high pitched metal sound as the dryer turns... may as well replace it and the belt while you are in there. 2 and a half hours of work if its your first time doing all of this work combines... just take your time and download a manual and print it out if you need to.
repair guys make a good living fixing very simple stuff lol... but its a pain.
I am not a professional, just a family man with limited financial resources and lots of trial and error... I have saved lots of money spending a Saturday or Sunday taking a crash course in appliance repair lol.
Posted on Nov 14, 2009
We were given a HOT POINT Heavy Duty Dryer with Automatic Dry Control, Model DLB2650BRLWH, Serial No. DG241274H and had to buy the power cord to go with it. Ordered the cord from a local appliance company,...
Technical explanation: Older 240 Volt appliances use a three-wire power cord (Black, White, Red). The White wire is the "neutral" connection, which is tied to Ground at the service entrance panel. The Black and Red wires are opposite phases of the 240 VAC (when one goes positive, the other goes negative). The neutral wire is "in between", so measuring the voltage between the black or red wire and neutral would give you 120 VAC. The green wire is frame ground; the electrical code requires newer (since 2008) 240 VAC appliances to have a separate ground bonding connection to the frame; the neutral connection is not considered adequate protection for certain failure conditions.
Look for a screw head or terminal stud on the frame or sheet metal of the dryer labeled "Ground", "Earth", or one of the following ground symbols:
The green wire goes to this point. DO NOT connect the green wire to any of the wiring inside the dryer, unless it is a green wire attached to sheet metal or a bracket!
The black, white and red wires go to black, white and red terminals you already found.
Mar 17, 2011 | Hotpoint Dryers
On the top of the dryer there is block where the power cord attaches and there are 6 spaded treminals wit the following wires attached from left to right they are black wire, 2 blank, whiye double wire,...
the green wire is the ground wire,there should be a screw or connector for it near the block,it just connects to the frame so the unit is grounded,you should see on the cord a white,black,red and a green ground wire,on the block you should see the white wire connected,the black on another screw and the last one is for the red,if the white is in the middle the black should be on one side and the red on the other,they are color soated,if you say there are red small wires the large red should connect with them just like the black does,as long as you keep the white wires together,the black wires together and the red wires together you'll be fine and ground the green wire to the frame
Feb 22, 2011 | Dryers
120v hot tub wiring diagram! Need to wire fro 120v! there is a red, white, black & green to connect the wire from the power plug. The power cord only has black, white & green. Which is the hot and...
I would expect your tub is either 110 or 220. Currently you are set up for 110. Based on that ... you disregard the red wire.
If your tub can run on 220, you should run it on 220 as this is more economical.
You should probably have an electrician check this out and make any changes to assure proper and SAFE operation of your tub. You are using a GFI, correct?
Thanks for your interest in FixYa.com
May 15, 2010 | Pool & Spa
I need info for changing the power cord from a 3-wire cord to a 4-wire cord. I have a Maytag Dryer Model MDE9316AYW and I am not sure wher to connect the wires. It looks like they connect (from left to...
The correct way is actually as such...Green (ground) to the frame/chassis. Red, white, then black. See the image I attached for a reference.
Hope that help`s. Good luck.
macmarkus :)
Mar 06, 2010 | Dryers
AEM407WZ Electric Dryer - 4-wire cord installation
red and black are the 2 power phase wires and go on L1 and L2 terminals or on an inline power block the 2 outer terminals(polarity)doesn't matter,then white is the center or N-neutral terminal, then green or green/yellow stripe is chassis safety ground and is connected to the metal frame of the unit
Mar 04, 2010 | Dryers
If you are installing a new power cord on a whirlpool dryer and you have a power cord with one green wire one black wire one white wire and one red wire where do you connect the wires when the terminals on...
Good day,
The green is screwed to any convenient place on the cabinet. It's a safety ground wire.
The white goes in the middle of the block. The red and black go on either end. Doesn't matter which.
Feb 27, 2010 | Whirlpool GEW9250 Electric Dryer
The power cord on my Whirlpool washing machine is not connected. There are 4 cables (red, black, white, and green). I can see where the black, white, and red, but where does the green one go? There is...
The following link explains how to correctly install a power cord on your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
The main difference between the 3-wire and 4-wire configuration is how the Neutral (WHITE) wire and Ground (GREEN or BARE COPPER) wire are terminated on the terminal block in the back of the dryer:
- In a 4-wire configuration, these two wires are INDEPENDENT of each other and are terminated separately.
Terminate the wires at the terminal block by matching the corresponding colors:
RED to RED (HOT) 120VAC
BLACK to BLACK (HOT) 120VAC
WHITE to WHITE (Neutral) 0VAC
GREEN (Ground) - attached to a ground lug that grounds it to the equipment cabinet.
If you have any questions, please let me know. I hope this helps you
Dec 24, 2009 | Washing Machines
I need to know how wires on the power cord connect
Red on the left.
White in the middle.
Black on the right.
Green on the case/chassis ground or green screw with the small dashes on it.
If you don't have a white wire but the the green in the middle position.
White/red = far left
Green = middle
Black = right
Jan 29, 2009 | Roper REX4634KQ Electric Dryer
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
Kenmore 65924 Electric Dryer Logo
137 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
