Question about Polaroid FLM-3232 Television
Tv just stopped this am... cannot get it to power
Tv just stopped this am... cannot get it to power on...
  • 11,361 Answers
You can download the service manual here: http://www.polaroidsupport.com/polaroid/en_us-sm.html
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 15, 2009
How do I stop tv going on standby
hi Shaun.
How do I get my TV out of standby mode? Press the power button once. If the TV does not turn on, observe the LED indicator, usually located on the TV's lower front panel. If the LED indicator turned off after you pressed the power button once, it is in standby mode. Press the power button once again to exit standby and turn on the TV.31 Mar 2015
How to Troubleshoot a TV in Standby ' Techwalla.com
https://www.techwalla.com/articles/how-to-troubleshoot-a-tv-in-standby Search for: How do I get my TV out of standby mode?
How do stop tv going on standby Google Search
Nov 26, 2017 | Televison & Video
At power up, tv scrolls uncontrolably through channels, power light flickers
1. Take remote control far away from tv - 3rd or fourth room. Then switch on tv. If uncontrollable scrolling stops , then cause may be remote button (Ch+ or Ch-) has got dirt inside and its shorting.
2. If taking remote far away doesn't stop scrolling then (Ch+ or Ch-) button on front pannel has shorted. Take a cutter plier and care fully remove button from its circuit board. ( If you know desoldering, it is far better than cutting). If scrolling stops then you can operate channel change with remote.
Jan 27, 2014 | Samsung LN46C600F3FXZA 46in Lcd Tv 1080p...
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
My tv just stopped powering on. Model 1911-TLXB
Have/Had the same problem, try disconnecting the vga cord from the tv, removing the power cable and reattaching the power cable. Turn the tv on and then connect the vga cord back into place. It doesnt make sense but i've been having to do this since i bought the tv
Sep 28, 2009 | Polaroid 1911-TLXB 19 in. LCD TV
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Tv stopped working
Hi. This tv may have an issue within its contents.This issue concerns the power supply board. to confirm this, unplug the tv from the surge protector, if any, and wait for 3 Min's. after this 3 min wait, plug this unit into a wall outlet and power up. if it dose not power up, you will defiantly have to replace the power supply board.
Please rate and god bless:)
Apr 02, 2009 | iLO IWT3206 TV
Help!
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
May 03, 2008 | RCA RCR412C Remote Control
Power problems
Something wrong with the power switch? Does it stop if you press any buttons on the TV (including the power button)?
Aug 17, 2007 | JVC AV-32D305 32" TV
Polaroid FLM-3232 Television Logo
70 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
