Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
HAVE MODEL 253.74162400 REFRIGERATOR THAT HAS NO POWER, POWRE IN IS GOOD. DO THESE HAVE A POWER RESET OR A FUSE SOMEWHERE THAT COULD BE BLOWN
  • Kenmore Master
  • 4,654 Answers
We need to check the power to the compressor are the fans or lights on? Sea Breeze
Posted on Nov 14, 2009
  • John Tripp
    John Tripp Nov 14, 2009
    Your model shows a defrost timer I think inside the fresh food compartment. Need to find the opening in the control panel where adjust temperature and turn clockwise to see if refrigerartor restarts.Click here and then on the Repair Guy=> Repair Clinic Part Number 12762 .
  • John Tripp
    You model is not very clear about were the defrost timer opening is but answer the part about the lights on if yes it may be the timer is stuck in defrost. Click here=> page 17 is where it shows a timer or adaptive defrost that is most likely the reason and area if the lights are the only thing on. Sea Breeze
    Click Here pg. 17 => http://www.managemyhome.com/mmh/lis_pdf/...
    Here if you need me SEA BREEZE
How do I find the fuse panel on LG model LSC269055b refrigerator
I think your model number is actually LSC26905SB
There isn't a fuse panel, per se. If I remember your model correctly, the main board is on the back, so pull your refrigerator out, unplug it, and take off the access cover located about halfway up your refrigerator's back. Look at the fuses on the main board. There is a 20 amp fuse that blows easily (the newer boards have a slower blowing fuse in them, now). Temporarily jumper the 20 amp fuse and then plug your refrigerator back in. If you hear relays clicking and such, that's good. The compressor should start up shortly afterwards and all the lights should be on in your refrigerator.
After you have verified operation, go to Radio Shack, or somewhere similar and get yourself a 20 amp slo-blo (slow blowing) fuse and solder it on top of the old fuse on your main board.
Remember to always unplug your refrigerator when dealing with the main board and power circuits.
Good luck and let me know if you need any more help.
Nov 17, 2014 | LG Refrigerators
Norcold 3163 Fridge
There is a 3 amp.fuse in the wiring behind the control panel or somewhere between the control panel and the terminal block. If the fuse is blown do not replace with any higher amperage rating more than 3 amps. Here is a Norcold 3163 Service Manual On page 10 of the service manual shows all of the components that the ac power goes through. Let me know what you find and I will be here to answer any questions you may have, Thanks Sea Breeze
May 08, 2013 | Refrigerators
Water & ice dispenser don't work
The button lock switch along with the other switches on the door use one common return wire for power to the solenoids. The freezer door light switch will stop power to the buttons if it has failed.
Jul 08, 2012 | Frigidaire PHSC239DSB Side by Side...
I HAVE A 1995 HITACHI 50UX19KV5F018305 THE TV WONT TURN ON
check for blown fuses, power regulators, in powr area, resoldering and general service is required...
Oct 30, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Saab 9000 lost power
The commmon thing is GROUND.
Probably the ground strap from the engine to the chassis is worn, broken, loose, corroded, or otherwise not making good ground.
Check the negative cable on the battery to see if the "pigtail" is disconnected.
Replace or install a ground strap from the engine to the chassis.
Do that first; otherwise, on the positive side, the inline 100Amp FuseLink may be blown.
Hope this helps!
Sep 17, 2009 | 1990 Saab 9000
The amp just turned off and won't come back on. fuse blown?
If you can see where the power wiring comes into the amp there has to be a fuse in there somewhere as the fuse is designed to cutoff all power when overloaded
Mar 24, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
JVC 36
Hi Dave: "My JVC 36" TV will not power on and has a blinking power light."
That means that the protection circuit has started because a fault had been detected.
If this happened after a power surge it is likely a faulty PSU board.
Try first leaving the set unplugged from power outlet for few hours, this will drain power, reset the protector, and fix problem related to accumulation of electrostatic charges on PSU power capacitors.
If unplugging does not work, that means that there is an internal fault.
If this happened after a power problem of some kind, that means that probably one of the capacitors on powr board had blown, and must be replaced.
The TV must be tested by a technician to find the fault.
Jan 05, 2009 | JVC AV-36D303 36" TV
Ge profile refrigerator won't run
Where is the click sound coming from. There is no fuse in the unit. If light comes on you have power. If it is a frost free refrigerator it will not come on if the defrost timer is in the defrost position. There is no reset button. Did you wait about 20 minutes to see if it would come on by its self?
May 23, 2008 | Refrigerators
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
152 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
