Question about Onkyo TX-SR605 Receiver
Front right speaker hook up defective.sound distorted
  • 458 Answers
Switch (R) and (L) speaker testing .....if sam problem need replaced amp ...
Posted on Nov 15, 2009
My sub woofer distort why is that?
Try another speaker - if it does the same thing your amp is damaged.
If replacement speaker sounds fine then your original speaker is defective.
Oct 31, 2015 | Altec Lansing Audio Players & Recorders
Sirius Sound only on front right speaker !!
is your satellite an external device? and if so what kind of adaptor or harness does it use to hook up with main radio?
Dec 27, 2007 | Kenwood DNX7100 Car Video Player
I don't know how to hook up the speakers
hooking up speakers is easy you if your terminals are red and black you just match them up black on speaker means hook to black on the receiver doing a wrong hookup can reverse the phase of the speaker cause a distortion and eventual damage to speaker and coil.if you are rtunning just a stereo that allows two speakers select speaker you want for left side and put that on left of the stereo and hook it up as left and same for the right and if you have a home theater you hook it all up the same but you hook up the center put it in center front of the room as far back to wall as you can but dnt cover it up it should be lower than the front left and right or the main left and right speakers.then if the5re is surround you put those like say you have a square room you put them in the corners on the back wall.if you have rear speakers you put them on the back wall.make sure all speakers excepty rthe center are level and equal distance apart
Mar 20, 2013 | Audio Players & Recorders
Distortion
The wattage rating, I take it, for the speakers is more than 45 watts right? Check to make sure that you connected the right wires to each speaker,front right + wire to front right speaker, not front right +, to front left + and make sure that the -'s are connected to the -'s, and the +'s are connected to the +'s.
Mar 29, 2010 | Alpine SXE-1325S Coaxial Car Speaker
Sony DAV-SC8. I'm suddenly getting distortion
It sounds like the speakers themselves are the problem rather than the amp.
Although, it would be rare to have overdriven/blown the surrounds.
My suggestion would be to isolate which speakers or channels (on Amp) are at fault.
Swap left and right to see if the problem transfers across.
Sep 13, 2009 | Sony DAV-SC8 System
I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Aug 10, 2009 | Yamaha RX-V2600 Receiver
Amp went into protect, but front speakers sound distorted too
If the amp still goes into protect mode, the easiest thing to do is disconnect the RCA cables from the amp and see if still goes into protect mode (after turning off/on). If it does, the issue lies in the amp or the wiring to/from the amp (most likely case). Check to make sure no speaker wires came loose and touched +12V or ground (car body). From the sound of it, my guess is something internal to the amp died and will need repair.
Mar 22, 2008 | Car Audio & Video
Distorted sound on all right channel inputs
yep but if your not a tech you should take this easy repair to a pro. Your problem is an open emitter resitor and happens when the units over driven or a speaker is bad for a while while it was working. if your a tech then check all of the emmitter resistors. also it could be a bad output device. Good Luck
May 27, 2006 | Yamaha RX-V496 Receiver
Onkyo TX-SR605 Receiver Logo
51 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
